Question about Philips 60P8342 60" Rear Projection Television
Tv turns off by it self
My JVC I art pro 42 tv turns off by it self after playing for 30 to 40 minutes My tv turns off and on by its self.
I just recently had the picture and sound fixed, now its doing this.
How can I fix this myself ?
  • missjojo17 Sep 01, 2008
    We have a 50 inch PTV916. There doesn't seem to be any sound, it takes forever for the tv to warm up and turn on, and if we push any buttons like the channel button, the tv turns off on its own. How do we go about fixing this?
  • bechat Mar 16, 2009
    the television turns off by it self.
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
Posted on Jul 02, 2008
2 Suggested Answers
TJBENGR
  • 121 Answers
SOURCE: Tv turns off by it self
This usually is heat related. Is the filter clean? The fan working? Otherwise there is most likly a "so called" cold solder joint...where the connection on a board is not positively made...often when it warms up the joint will 'open'..disconnect. This needs re-soldering.
Posted on Apr 21, 2008
CAfter the JVC model LT-42E910 is on for 10 minutes, the picture goes blank/black, but I have sound. I must turn off the tv and turn it back on every 5 minutes to get a picture. The tv is 4 days old.
It is a new tv.Take it back where u bought it and trade it in for another tv.This tv have those 2 LCD long inverter boards have problems.These 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the tv LCD screen to produced a picture.
Jul 07, 2011 | JVC LT-42E910 42" LCD TV
Have pioneer pro-950 hd plasma tv. Has been working great. turned on this evening and got a display saying Plasma Display - starting up. please wait. nothing happens? can't find anything in the manual...
Tries unplug,replug both tv and cable box an hour later.Let the tv reset it self back to the factory setting.The cable box to upgrade it softwares.The tv now should,work again.
Oct 20, 2010 | Pioneer Elite PRO-950HD 42 in. Plasma...
II HAVE A JVC I ART PRO TV AND ITS SEEING DOBLE
this is a convergence ic problem , u need to replace the convergence ic take the front speaker grill off and the cover for the picture tube , stk392-110
Aug 25, 2010 | JVC Televison & Video
Jvc i art av 36f475: no sound
Good Day sir/maam, my guess are several, lets start at the common ones, make sure that the AV cables are good. you can try swapping cables to make sure. If possible try the cables on other units such as any DVD player. There is a possibility that the sound jack, is bad, try to vibrate the plugged cable, and see if the sound goes back if it does, you need to solder the terminals. Worse is the Amplifier section of the TV. does the TV sound normal on broadcast? check the volume, mute. or the TV setup. hope this helps. if you have additional info please feel free to ask again, let me know any progress. thanks
Jul 28, 2009 | JVC AV-65WP55 65" Rear Projection...
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
TV SHUTS OFF AFTER A FEW MINUTES
Very likely to be a heat issue, the first thing to do would be to clean the ventilation slots in the back.
Feb 28, 2009 | JVC AV-60D501 60" Rear Projection...
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Mar 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Red streaks
need to have the STK IC's replaced to correct convergence problem
Mar 05, 2008 | JVC AV-27230 27" TV
Philips 60P8342 60" Rear Projection Television Logo
151 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
