Question about DeLonghi Microwave Ovens
I need instructions in English for my MW-580 microwave oven.
MicrowaveSvc
  • 9085 Answers
SOURCE: instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
  • 63 Answers
SOURCE: National NE-ES25 Microwave Oven
hi my name is mark, i have been checking the web this is as close as to finding the manual as i could find http://owneriq.net/ hope this helps. thanks for your question.
Posted on Mar 18, 2009
  • 177 Answers
SOURCE: Need instructions in English-Americans living in
Call thr Customer Service number located in the existing booklet and ask if the manual is available in English.
Posted on Aug 06, 2009
SOURCE: Onn microwave/ oven. Need instruction manual
call adsa electrical on 0845 3007775 and they'll email you the instructions
Posted on Nov 16, 2009
I have a Corningware MW-A-10 Microwave Browner which I have never used - could I use it in a conventional / thermofan oven?
No. The bottom of this utensil is coated in tin oxide. It is not recommended for use in any appliance other than a microwave. Tin oxide (SnO) is flammable and particles may contaminate your food. It is suggested that you use the MW-A-10 only in the microwave, or look for a different CorningWare piece that is not in the MW series.
Oct 07, 2010 | Microwave Ovens
Display on my westinghouse microwave says CHIL it wont work now
hello,
what you are to do to fix up the problem is that,put iff the the oven for some time and allow it to relax it self with out an operation, then put it on again then if it has time programming or reset button then click on an of this button for it to restart it self ,
but if this problem remain then you will have to open the the oven then trace the wire down to the panel to clean up any from of dirt or liquid around the panel then couple it back at it was with this the problem will be solve.
thank you and thanks for using fixya.
Jun 14, 2010 | Westinghouse WST3504 Microwave Oven
How do I remove my ge jvm 1653 microwave?
Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
Apr 09, 2010 | GE JVM1653 Microwave Oven
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
HOW TO UNINSTALL A WHIRLPOOL OVER THE RANGE MICROWAVE. iT IS IN A HOUSE WE JUST MOVED INTO AND IT IS BROKEN. iT IS ALSO HARD WIRED
Since you did not give model number I am providing info for one type of MW that may be similar. If you want specific info for your MW find model number and consult this page: http://shared.whirlpoolcorp.com/product_literature/search.jsp
Otherwise here are the installation instructions I found that you can use in reverse to figure out how to remove your MW.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%20W10238252A.pdf
Aug 11, 2009 | Microwave Ovens
Aug 06, 2009 | Microwave Ovens
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Fuse
behind the MW panel
Unplug the MW
took 2 screws from the top plate than one screw for the panel
May 13, 2008 | Sharp R-1481B Microwave Oven
Microwave Ovens Logo
266 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
