Question about Electrolux E24CM75GSS Coffee Maker
E24CM75GSS-I NEED TO KNOW HOW TO CLEAR MESSAGE:PLEASE WAIT REFILL RESERVOIR.THE TANK WAS REMOVED AND CLEANED.IT HAS BEEN REFILLED ,BUT THE MAKER STILL DOESN'T RESTART.WHEN YOU LIFT THE TANK A LITTLE THE MESSAGE CHANGES TO CLEAR GROUPS.IT MAKES STEAM AND HOT WATER IN THE TUBE,BUT NO OTHER BUTTONS WORK.
    President:
  • 2,777 Answers
Yikes, have you tried just cutting power to the unit / pulling the power from the power source, and letting it sit a good 10 minutes? It sounds like the sensor involved with the reservoir is having issues there... Hopefully it's not a failed sensor, resetting it like I described will jump-start those sensors many times, let me know!
Thanks
Tim
Posted on Oct 08, 2010
Says to prime
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement.
Jul 17, 2014 | Keurig Platinum B70 Coffee Maker
Keurig B70 automatically pumps water when turned on
When you purged the lines or tubes retained debris and need full purging and flushing.
May 30, 2012 | Keurig Platinum B70 Coffee Maker
My Keurig Brewer is flashing the add water, heating and small cup brew lights. The water reservoir is full and I have taken it off and placed it back on. If I press the small brew button it acts like it...
Perhaps more than one problem people are dealing with but here's what I found. The round float in the tank is magnetic so it's either activating some crappy mechanical switch or more likely a hall effect sensor. Remove the tank and dump the water so the float will rise from the bottom when you refill it. Take a good strong magnet and slide it around the side of the unit where the float would be, tapping it as you go. Put the tank back on and fill it. One try and I was back to making coffee.
Aug 13, 2011 | Keurig Elite B40 Coffee Maker
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Apr 23, 2010 | Keurig Platinum B70 Coffee Maker
How to clean the Keurig coffee maker.
fill the reservoir with distilled white vinegar and leave the brewer on for 4 hours (leaving the auto off option OFF). after the 4 hours, run the entire vinegar filled reservoir through the machine.
refill with water and repeat twice. your machine is now cleaned and descaled.
Apr 05, 2010 | Keurig Elite B40 Coffee Maker
Keurig Platinum is clogged
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
On my printer MP530 I get the following message: INK LOW M, I have refilled the tank M (color red) which was empty and the message continues.
refilling the tank does not solve this problem, canon design this printer to have their ink tank replaced, so do not worry too much about the ink level, as long as the printer prints you are fine....all you need to do is refill every time the print quality is not good, don't wait for the ink to dry up, this could cause damage to the print head.
Sep 25, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Bunn coffee maker reservoir makes a gurgling noise
THis sound is usually caused by the water being low in the tank. This can be because the machine is left on for long periods without being used. If this is not the case, then it would probably be your heating element getting small holes in it.
Jan 12, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
New Primea Touch Plus Machine
in the water container they is a float .the float is probably stuck tap gently the container it should work cheers
Dec 25, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Electrolux E24CM75GSS Coffee Maker Logo
179 people viewed this question
Top Electrolux Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Electrolux Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
