Question about Lands Phones
My phone disconnected twice the 3rd time the unit got extremely hot then shut down. whats wrong.
    Problem Solver:
  • 7 Answers
Chinge battery
Posted on May 30, 2008
Why is my air conditioner unit only running properly on cool days? when its hot out it only runs about 5 mins at a time then shuts off to fan and dont come back on for another 20 mins.
Do you hear a click sound as the compressor shuts down? If so that is the clixon (heat sensitive circuit breaker) that is opening and shutting down the compressor when it overheats. You have not had the AC filled with refrigerant so overfilling the unit cannot be an issue.
And if it is not overfilled overheating is caused by excessive current going into the motor which could indicate a problem with the motor windings..
OR, If the thermostat is faulty it could be prematurely shutting down the compressor. If you jump (bypass) the therm and unit does not shut off then you have found the culprit.
Sep 08, 2015 | Heating & Cooling
My 2003 Mazda tribute wont start when car is warm after being shut off for ten minutes. Has happened twice now, what is wrong? Will start after cooling down as if nothings wrong.
There can be a number of things to look at. the coolant temp sensor or the fuel pump. the coolant sensor tell the ECU when hot or cold,and it can be telling the ECU the motor is to hot. the fuel pump could be over heating and shutting off
Oct 23, 2012 | Mazda Cars & Trucks
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
#GLHS35E4SB6 Frigidaire side by side. evaporator motor area becomes extremely noisy and eventually shuts off. The fan could be floating on the motor shaft and engaging the shroud. Apparently the...
be sure maybe the sound coming from evaporator fan some times it accumulate ice near it do not open for long time both doors or put hot things inside the fridge or freezer .
Sep 11, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Ruud Model RQNA-B 13 Seer heat pump and it has shut down during this cold snap. It does this everytime it turns extremely cold and in the summer when it is extremely hot. Help, the service men...
If the outdoor unit is not operating and the electric heat is working, more than likely the outdoor thermostat is keeping the unit off.
This is an adjustable setting, doing it at the outdoor
unit. Typically the unit is ste anywhere from 15-35
deg outdoor temp. If it is 20deg outside and unit is not operating you turn it down to 15 deg to get the unit to run.
In the summer time if the unit is placed where it is
extremly hot most of the day, then the unit is
probably either shutting down to the compresssor
internal overload,which resets on its own. Or it
is tripped out due to a High pressure switch
whick can be reset manually or automatically depending on the unit.
The High pressure switch is located on the liquid line
which is the smallest of the two refrigerant lines.
If its a manual reset,just push the button in.
If you can get the unit to run, check to make sure
the outdoor fan is operating.
Good-Luck
Jan 09, 2010 | Heating & Cooling
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Yamaha HTR-5890 Receiver
Hp 6720s lap top running - vista does not load
If the laptop runs extremely hot, then CPU will shut down (thermal overload) and will not boot up again until it has cooled down.
Overheating problems is caused by faulty fan (stop spinning) or the fan and heatsink assembly is clogged with dust. Check the fan, it should spin freely and remove and vacuum the dust from the fan and heatsink.
Replace the fan if it is faulty.
Aug 03, 2009 | HP Compaq 6720s PC Notebook
Acer 5570 southbridge overheats and shutsdown
well,if you r able to get to bios then check power managment sction and reduce CPU speed and try to deactivate one of the peripherals that is responsible of thi shorting out= over warming.
as long as the southbridge chip over warms every time you turn on you laptop thats mean the S.B is facing a shorting out on it IC.
you can clean underneath/surround it.
plz rate.
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
