Question about Kenmore 98702 Stacked Washer/Dryer
The dryer works, makes noise
Hello! Thanks for being here!!! When I turn the dryer on, it rotates, but makes a weird noise. When I open the door, it stops, but it sounds like there is another barrel around the barrel I can see that doesn't stop.
YOU HAVE ONE OF TWO THINGS GOING ON EITHER THE IS DEBRIS STUCK IN THE BLOWER AND/OR IN THE DRUM FELT OR YOU HAVE A DRUM ROLLER HAS FAILED AND HAS A FLAT SPOT ON IT USING YOUR MODEL NO# GO TO WWW.SERVICEMATTERS.COM AND PULL UP THE JOB AID MANUAL TO ET INTO THE MACHINE
Posted on May 29, 2008
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
G e profile dryer makes scraping noise while rotating clockwise
your top door bearing and glides are worn out,remove 4 top control,panel torx screws,then open door and on the top of the door land are 2 screws holding the top panel,remove these,then push top to the left or right to remove from the catches at the back,then unplug door switch and light wires from door to unit on lower left side,lay door on smooth surface and un clip top door bearing,replace worn out bearing along with white and/or green glides,whatever unit calls for,some use only white and some use white and green glides
Mar 11, 2012 | General Electric DCVH680EJWW Dryer
I have a speed queen dryer and all it does is hums and instantly has a burning/hot smell. Any help would be great, thanks.
Hello James,
If you can rotate the dryer drum easily by opening the door and rotating by one of the drum baffles and it rotates easy and noise free,the problem is going to do a bad motor
Gene
Aug 08, 2011 | Amana NDE7800AY Electric Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Mar 13, 2011 | Dryers
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
Maytag dryer won't rotate after blower wheel replacement
The dryer belt may have broken or come off its pulleys. Pop open top of dryer or rear vent door to look inside to see if this is your problem. Let me know if I can help, Thanks Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
62 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
