Question about Dryers
Kitchen cabinet doors will not stay closed - Dryers
tborn6
  • 700 Answers
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Posted on Mar 26, 2009
SOURCE: I am making new kitchen cabinet doors.
If you are using European hinges then then you will need a 25mm forstner bit for your drill. Using a drill press with an adjustable depth stop is recomended.
Posted on Nov 20, 2009
Testimonial: "thank you very much for your help *******"
  • 3293 Answers
SOURCE: weber cabinet door won't stay shut
Try moving the catch foward there are two screws on the sides you can losen and move the catch
Posted on Feb 25, 2012
  • 26 Answers
SOURCE: Kitchen cabinet doors pop open
If the hinge is out of alignment, or simply worn out, replacement may be necessary. But, if the problem is the cabinet door (warped, or enlarged screw-mount holes) a new hinge will give you the same issue you have now. A small magnetic catch may resolve your issue with less expense and no alignment needed. It involves a small (1" square) metal plate with a single screw which you attach near the the lower corner that hangs open. The complimentary magnet attaches to the door frame of the cabinet housing (inside the cabinet). Available at even small hardware stores, the catches cost about a buck, install in a minute or 2, and will discretely solve the problem shown in your video.
Posted on Jan 10, 2015
  • 51596 Answers
SOURCE: Damper door stays closed blocking the cavity lamp when oven door is in the open position
sounds about right to me . that is why I would never own a built in .
Posted on Feb 04, 2015
My oven gas burners shut off with door closed after staying on few minutes first
I think it could be a ventilation problem and especially since the unit is new the fact that you have to leave the door open to get it keep running indicates that it needs more air be careful this is a gas and give out carbon monoxide which can kill you
Mar 17, 2018 | Kitchen Ranges
May 05, 2013 | Hardware & Accessories
How do you install an Ikea kitchen cabinet door hinge?
The new Ikea Sektion door hinges mount in 2 holes that are horizontal. The dimensions for the hole placement are 62 mm up from the outside bottom of the cabinet where the bottom edge of the door will be. The first hole is 20 mm in from the front edge and the second hole is 33 mm from the first hole or 53 mm from the front edge. The holes can be drilled with a 3/16" bit to a depth of 9/16". After the holes are drilled, the plastic plugs on the back of the hinge mounting plate are pushed into the holes with the orientation triangle "arrow" stamped on the front of the mounting plate pointing toward the cabinet opening. After the mounting plate is flush with the surface, the two wood screws are tightened in the plastic plugs to expand the plugs and secure the mounting plate. The door hinge mounted to the door is then clipped onto the mounting plate by first engaging the "hooks" near the door end of the hinge then snapping the back end of the hinge into the clip at the rear of the mounting plate. The location of the door once mounted can be adjusted by turning the three screws on the hinge. The front screw moves the door right and left when closed. The center screw (recessed in the hinge) moves the door up and down. The back screw moves the door closer or farther from the cabinet when closed. The hinges "snap" the door closed, so if the door is too close to the cabinet the hinges can't snap it closed and the door remains ajar. The trick is to adjust the inner screw to move the door farther from the cabinet until it snaps closed. The snap can be strong, and the little bumper plastic disks you can stick to the door to soften the bump work to some extent. The best solution is to install one soft-close Utrusta piston per door. The piston clicks onto the hinge and slowly closes the door the last bit without a bang.
Jan 31, 2013 | Hardware & Accessories
Can you buy kitchen carts with closed cupboards underneath?
Yes you can buy kitchen carts that have cupboards as well as shelving and hooks. Take a look at the overstock.com site http://www.overstock.com/Home-Garden/Solid-Wood-Kitchen-Cart-with-Double-door-Cabinet/3309401/product.html
Sep 10, 2012 | Furniture
MZD2766GEQ - MAYTAG Side-by-side refrigerator fresh food door will not stay closed? hinge or gasket? inside seal?
Normally the most common fix for the doors is to level the cabinet. Leveling the cabinet will also adjust the doors to help level them and help them close properly.
May 04, 2011 | Refrigerators
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Nov 13, 2009 | Tools & Hardware - Others
Dryers Logo
Top Dryers Experts
