Question about Royal Office Equipment & Supplies
The wheel got dislodged and now I can not line it up properly so it will type-also space bar is sticking badly.
    Champion:
  • 204 Answers
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, the it should be ok. If not try it again. Check to make sure no pedals on the printwheel are bent.
Posted on Mar 30, 2011
Space bar on sylectric 2 ibm typewriter is not moving the type
There are a few things that can cause your spacebar to not move the carrier. Do you hear any sound when you press on the bar? There are adjustment that may need to be made to the machine or perhaps there is something sticking in the mechanism. Unfortunately you mey not be able to fix this yourself as these machines need a technician to properly repair and service the machine.
Feb 15, 2015 | IBM Correcting Selectric II
Olympia Startype 3 occasionally types double vertical line and spacing is changing between letters
Check the printwheel for any broken or bent spokes. vertical lines means the wheel is between letters so either a problem with printwheel or something preventing wheel from turning normally.
Sep 15, 2014 | Olympia Startype 3 Typewriter
Smith Corona Super 12 space bar sticks
Most likely a bad spring under the space bar. But check for paper clips or other stuff just to be sure.
Dec 11, 2013 | Smith Corona Wordsmith 200 Typewriter
Space bar sticking keyboard
There is something under the space bar you can pry it up carefully and remove the debris it should snap right back in.
Oct 31, 2013 | HEWLETT-PACKARD Computers & Internet
Xerox memorywriter 6020's space bar sticks
Under each key there is a contact pad, they get old and the foam falls apart. They can be fairly easily replkaced the pads are 1.50 apiece.
Befor you do anything realize that the ribbons are no longer made.
DickyO
Jan 16, 2013 | Office Equipment & Supplies
Bath tub/shower has no space for a grab bar to assist getting out of the tub. Back wall of the shower is nearly flush with edge of tub. Grab bar would stick out and be in the way. Is there some type of...
There are newer style suction cup type grab bars available at Walmart that are very effective and don't require a permanent installation to a wall. These are able to be mounted on shower/tub walls and can hold quite a bit of weight, when properly installed.
We did this in our house as my wife had leg surgery and needed these in order to get in and out of the shower and tub while recuperating.
They were a bargain and removable once she recovered, but you can leave them in place as long as you wish.
Give them a try, I think you'll find them very helpful.
Hope you found this info helpful and best regards!
Aug 06, 2009 | Home
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
48 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
