Question about Toyota Sewing Machines
How to rewind a spool on a toyota electric sewiing machine
  • 340 Answers
Http://www.aisin.fr/catalog/download//Bobbin%20winding.pdf
This is from the Aisin site, they deal with Toyota machines.
Hope this helps!
Posted on Oct 09, 2010
My machine will sew for about 6 inches then it loops the thread and jams, I have tried retreading the machine, changing the needle and rewinding the bobbin.
I think that your thread is unwinding the wrong way, try turning your thread spool upside down and see what happens.
Jan 12, 2018 | Sewing Machines
Thread bunching
90% of the time I find re-threading the spool and the bobbin can help.
Next step, rewind the bobbin.
Also, the needle could be old, or the wrong size or weight for the fabric you are sewing on.
Dec 02, 2013 | Singer 57817 Computerized Sewing Machine
Can't get the bobbin off the rewinder spool.
There should be some kind of release button or switch.
Sep 02, 2013 | Sewing Machines
The bobbins doesn't wind easily and tight
When winding the bobbin, go slower not faster. And make sure that you have it threaded right, follow the diagram carefully with the thread unwinding from the spool the right way. You can take your tight bobbin off and use that as your spool and rewind onto a fresh bobbin. You cannot be a "speedy gonzalez" and have it be even.
Mar 01, 2011 | Singer 3116 Simple
I have an Emerald 183 sewing machine.The bobbin thread is too loose. I can pull the top thread out no problem. I tried rewinding the bobbin thread, changing the needle and I do use the right settings for...
Clean any tangles from the bobbin area.
Always thread a sewing machine with the presser foot up so the thread can properly seat into the tension control.
Hand walk a few stitches to see if the thread still feeds too fast from the spool.
When thread pools (falls off the spool) a thread net will help - you can get these at a sewing machine dealer. I use to find them at fabric stores, but have not seen any lately with sewing/serging notions.
Mar 19, 2010 | Husqvarna Sewing Machines
The top stitches are taught but the underneath (from the bobbin is loose and knotted
Your bobbin thread may be tighter than your spool thread. Try rewinding another bobbin with less tension or tighten the tension from your spool.
Feb 13, 2010 | Bernina Sewing Machines
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Feb 08, 2009 | Husqvarna Lily 540 and 550
Bobbin winder wont engage properly
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing regards,
Hope it may helps you;
Regards,
VOTIT
Sep 19, 2008 | Singer 3116 Simple
Sewing Machines Logo
60 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
