I have replaced the bulb, ballast,and color wheel.The tv worked well exept it would not restart unless it was cool. Now it shuts off the picture after 5 minutes but the bulb is still on. Could it be the cooling fan?
  • 11,800 Answers
No - if it would have been the cooling fan the bulb would have been shut down. It's much more likely that the problem is in the power source - as it heats up a bad contact fails. You will gonna have to check every soldering and redo all the ones that look or feel suspicious.
Posted on Oct 08, 2010
Model WD-65734. Why is there no picture?
Never heard of a color wheel needing to be replaced. Both cooling fans need to be clean and turn easily. Color wheel fan needs to turn easily. If any one of these motors does not turn, the controller will cause a shut-down. The Xenon lamp uses high voltage to operate. If the power supply was damaged, the lamp won't light. The sparking on the ballast board indicates that dirt or dust may be causing the problem. Also, the clamping diodes and regulator may be defective. If possible, try replacing the lamp power board. Regards.
Dec 22, 2015 | Mitsubishi WD Televison & Video
Hello, I have a Samsung HLP4663W 46 in. Rear Projection HDTV Television, and they lamp kept going out so I bought the proper lamp to replace it and it still would not show a picture. Should I pay to have...
Recheck the tv projection lamp installation?Recheck the lamp door latch,see if it is proper closed and tightly closed of the lamp door?Hear any clicking noises,when the tv projection lamp tries to ignite up.If hearing constance clicking?Mean the tv board that call the Ballast board it is also dead,this Ballast board only job are to ignite the tv projection lamp only.Ballast board must have be replaced.If the tv have a colors wheel is it dead or damage and broken require changing,u will hear major humming,motor or grinding sound noises and alot of times the tv pictures flashes multiples colors on the tv screen or the tv pictures will have a black&white flashes of a background of white light within the tv pictures background.Selling defective tvs almost impossible to sell it for a decent or a good priced or it at all.If this tv u have less than 5 years old,tv it is still have alot of it life ahead of it,tv tube picture screen panel,will last u atleast another 10 years and have to be 8 hours tv whatching every day to dies this faster or could be last to 15 years,if tv less hours of watching every day.Should get priced quotes from many tvs repair shops and get it fixed max prices about $400-$500 dollars.New tv same model and sized or difference models too will cost u like $1,200-$1,500 dollars.
Aug 06, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I have a Samsung HLP4663wx xaa that I just replaced the color wheel to fix the buzzing noise and then had to replace the lamp after 16541 hours so definately got my moneys worth. Had to remove the jumper...
I would assume you need to replace that ballast. Usually the bulbs out live the bulb's ballast (from previous experience)...I've seen DLPS do this type of thing when the bulbs are slow to turn on due to a new ballast being needed.
Thanks and hope it helps!
Jul 07, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
We own a Samsung DLP-TV. Last night it started shutting itself off. WE changed the lamp, but it is still shutting itself off after a minute. First, the picture goes off black, then the entire TV shuts off....
Do you still have your old lamp? try to see if it still works.. i think the problem could be something with your Ballast or maybe the color wheel.
Does your TV makes a strange sound? if it does maybe one of those 2 ballast or color wheel.
LETS TRY THIS....... MAYBE IT WILL WORK.
the Door lamp switch could be faulty, you've got to check it need to close fine with out the switch to go down
here is a picture that i found it looks like this!
and if not.. you can probably call this number the will give you free service.. i have tried it before =] (800) 281-8860
Mar 09, 2010 | Samsung HL-T5675S Television
I've recently replaced the bulb, thinking it would solve it from turning off (powering down) every so often. Replacing the bulb slow the problem down, but as of late, the problem has worsened. I've also...
Ballast board it is what powers Lamp on and CK the Lamp Fan if it stops and is not keeping Lamp cool then set will shut off.Fans are not to stop running while set is turned ON. Encompass Parts Distrubtion
1-800-638-3328 they might have it in stock.
Feb 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
The tv makes a loud noise - timer/lamp lights light up but no picture/sound. Changed bulb - tv worked for a short while. Now issues starting all over again. What could be causing this?
Ballast Board that connects to Lamp it could be bad or recheck to make sure its pluged in good anyway Ballast Board is what turns Lamp on Loud Noise means Color Wheel which can also shut set off Id say Color Wheel Call Encompass Parts 1-800-638-3328 they List all the Parts you need Part# for color wheel is BP96-00674A cost 129.69 They also have Service Maualfor your TV. Also Look on E-Bay under Electronics found some good deals thier Got my Lamp for 85.00 and Ballast Board for 65.00
Nov 18, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
Loud buzzing sound
Hello Jack,
That buzzing might be two things. It could be the color wheel or the ballast for the bulb. To check this you will have to move the projection section of the TV out of the case and listen for the sound in the area of the color wheel and the ballast. Try removing the color wheel power to see if the buzzing stops if it does then it's the color wheel is not and the ballast is buzzing then It's the ballast, and it will need replacing or if you know electronics you could try fixing the old ballast (I would suggest getting a new ballast).
Better still if you are uncomfortable working on the set you could get a qualified TV repair person to repair your TV .
I hope this helps,
Thank you,
Shuttle83
Jan 07, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
