Question about Microsoft Windows Server Standard 2003 for PC
How to install a print server in a small organisation
    Problem Solver:
  • 6 Answers
I assume (since no details were given) the operating system is already installed and the server is joined to the domain.
In the administrative tools of the server go to MANAGE YOUR SERVER and click on ADD OR REMOVE A ROLE. Click NEXT and the select PRINT SERVER and then click NEXT and follow the wizard prompts to complete
Posted on Oct 08, 2010
Is there a tool which can give a report of the message logs
If you are referring to OWA as Outlook Web Access for your organisation, then your email is likely being handled by a Microsoft Exchange server. You'll need to be able to access the Exchange Administrator in order to turn on logging of OWA events.
You can monitor most other Exchange activity directly by turning on Diagnostic Logging for the components that you need to see. Of course, you cannot view email activity 'outside' of your organisation.
Which version of Exchange Server is being used by your organisation?
Jan 15, 2013 | Computers & Internet
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Jan 30, 2011 | Zonet ZPS2102 Print Server
I have 20 nos of L300 device,each client has its own printer.The problem is that when I connect two printers of same model say hp laser jet 2014 on two different clients ,the printer does not work it shows...
The way the NComputing solution works, all the users are sharing the same host. So when you connect two printers, it's as if two printers are connected to that one host PC. When suing the USB port on the L300 you may have issues every time the device disconnects (like when a user logs off from their session) because the printer and it's respective port may have to be re-enumerated by the host. If possible, it might be better to do network printers. Also, when installing the printers, especially if you have the same make and model, make sure to LABEL them with unique names, i.e. Printer1, Printer2, etc. Otherwise, the host may have difficulty, more so the user, knowing which printer is 'theirs'.
Jan 25, 2011 | NComputing L300 Terminal Computer PC...
"how to print settings for
If you are talking about one of the TallyCom print servers there is a small blue test button on the side of the box, press this when the print server is connected to a printer that is online. If you press the test button for over 9 seconds the print server will be reset to factory settings. If you want to print from DOS to a network printer as I recall you have two options; 1) Install the printer in Windows and share it, you can then print to the share name 2) Use "NET USE" command in DOS to map a local port to a network port, this is nessesaey if you can not print to LPT1 or COM1 from the application. For help of NET USE go to DOS and use the help options.
Jan 05, 2011 | Tally (43555) Print Server
Added small business server. IRC 2550 will no longer print.
Most IRC2550's come standard with UFR printing and not PCL or PS3. If either or the 2 are installed instead of the UFR driver, it will act as if the print is going to the printer but nothing will come out. Verify which driver is installed and if needed, load the correct one.
Here is a direct link to that models download page Click Here
Aug 27, 2009 | Canon iMAGERUNNER 2830 Copier
D-Link DP-301P+ Print Server issue
- Kindly try to update the firmware of the Print Server.
Feb 24, 2009 | D-Link Express EtherNetwork DP-301P+ Print...
HOW TO RESET LEXMARK N400E
Are you sure the model is N400E and not N4000E ?. Try the following steps to reset the Print Server:
1. Remove the power cable from the Print Server
2. Take a pencil and press the small button on the back of the print server. Above the button is a label with "Test" written on it.
3. While keeping this button pressed insert the power cable back into the Print Server and then let go of the button.
Hopefully this should reset your print server.
Jan 07, 2009 | Lexmark N4000e Print Server
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
I think you mean email *facilities* although your version may be more accurate :-)))
You can't just download it - you have to buy it. If you want it for a relatively small organisation it is much cheaper to buy SBS 2003 which includes both Server 2003 and Exchange as well as other useful things. It's also relatively straightforward to install & get working although I highly recommend reading one of the many guide books that are available first.
If you really need to install them separately and have not set Exchange up before (or been on a course on how to do it) you are likely to have serious problems getting it working. It's complex, requires quite a bit of specialist knowledge and there are many pitfalls.
Sorry I can't be more helpful :{
Dec 29, 2007 | Microsoft Windows Server Standard 2003 for...
Reset edimax print server configuration
try to look for that tiny button around your print serverit is the resetter, it is the same with routers. does your print server comes with a cd installer, if yes install your print servers driver then you can assign your desired configuration for it.
Sep 09, 2007 | Edimax (PS-3205U) Print Server
Microsoft Windows Server Standard 2003 for PC Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
