Question about Kenmore Refrigerators
What wire order should be followed to install the light swith for a bottom freezer switch #4387911
    President:
  • 1,932 Answers
Please check the below wiring diagram
Thank You
Posted on Oct 08, 2010
Kenmore 795 elite icemaker non functional. Old icemaker would not manual cycle. Installed new icemaker, still does not work. Water works in dispenser. Auger motor works. Is there a fuse link?
You failed to give a model# so I can refer to what refrigerator you have.
Some will have a green light on it,some will not. Some have an on/off switch, some do not.. And some need to be turned on from the controls/user interface.
There is usually a fusible link wired in with the heater but it would have to stay open in order to trip it so I doubt this is your issue.
First, I would see how to turn it on. (Most side by sides have a rocker switch on the icemaker and typically have a green light.. Top freezer's are usually the same. Bottom freezer's with the icemaker in the freezer usually have no light on the icemaker but do have a rocker switch ((( Note *** Some, but not many are wired through the light switch so trying to cycle with the door open will not work.. You need to close the light switch either mechanically or with a magnet if it a magnetic switch)))... Bottom freezer French doors can have an on/off switch,typically no green light,or no on/off switch and needs to be turned on by the controls.
Pleas give more info if you need more help as there are probably 1000 variations of a 795 elite refrigerator as it has been produced for roughly 14 years now.
Jan 29, 2018 | Kenmore Refrigerators
Freezer model ul2494ecw2
If you hold your finger on the light the fan should come on if not you could have a bad fan motor, fan swith , or wiring
Mar 22, 2014 | Smeg FA311X Top Freezer Refrigerator
Light not working
Replace the light switch at the top of the door opening. Kill the power to the unit, pull down the grille up top, then remove the cover over the switches. the light switch is the one with the white back. The one with a black back is the fan switch. pull the 2 leads off, open the fridge door, squeeze the switch with a pair of pliers to pop it out of the opening, then install the new switch in the opening facing the same direction. put the wires back on , in any order doesn't matter, put the cover back on the switches, then the grille back on and restore power to the unit.
Nov 10, 2013 | Sub-Zero 611 / O Bottom Freezer...
Pilot light works fine not to big or to small i can jump the top and bottom wires and the unit will fire off and burn correctly, myself i think the thermopile that conrols the wall swith is bad or the...
If you can jump it (bypassing the switch) and it operates correctly, then yes. It is either the switch, the wires leading to the switch, or a loose connection of the wires on the switch or valve.
Nov 29, 2012 | Heating & Cooling
My phone hanged after installing two antivirus in nokia 5233.what to do?
pree green key,rad key,camera key and swith on bottom all bottom press same time and wait untill mobile swith on then follow instrotion and ur problem solution .i am also suffer this problem now this its help me and for u.thax
Jul 22, 2011 | Nokia Lands Phones
When idleing the lights go good but when you rev bike lights dim
Follow the leads that exit the crankcase from below carby area and thoroughly check all these connections to CDI unit and Rectifier and Ignition Coil. The wires also then follow thru' engine kill switch and lighting switch, others go to tail and brakelight switch. Are the wires being pinched at head stem or within handlebar switches. If all wiring/swithes and connections are in good order, you have some issues with your stator coils or pick-up coil inside left engine cover and behind the rotor, or the CDI unit. With some luck, the Rectifier or Ignition Coil may be guilty as these are relatively cheap to replace compared to stator coils and CDI. Get an auto. elec. multi meter check done. The Service Manual (info can be asked from Suzi dealer) has the Ohms resistance parameters to test against. Goodluck, and Cheers.
May 12, 2010 | 2001 Suzuki DR-Z 400 SE
Light stays on with doors closed
press the swith by hand,work,check the door if it touch the swith.otherwise,ckech the swith
Mar 30, 2009 | LG LRFD25850 French Door Refrigerator
I have a Heath Zenith 6133. It is a battery operated light switch with another swith that goes into a "box with a black and red wire coming out of it... could lyou send me the manual. thanks
The battery operated switch sends a wireless signal to the "box with wires," which takes the place of an ordinary light switch.
Turn off power, remove existing wall switch, and wire as follows:
Using wire nuts, connect "O--O", "A--A", "B--B". Both 'wireless' and 'receiver' now act as 3-way switches.
Dec 06, 2008 | Electrical Supplies
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
