Question about Brother MFC-7440N Laser Printer
My MFC-7440N says that the fuser cover is open but I have checked everything and it seems ok, there was a paper jam inside and I did remove it easily but now this msg has been on.. what should i do??
  • 13 Answers
SOURCE: How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Posted on Nov 30, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Posted on Dec 28, 2007
SOURCE: paper jam in brother MFC 240C
the paper ripped at the corner in little pices and it is jamed in the printer how can I remove it
Posted on May 31, 2008
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
DekeTheGeek
  • 25 Answers
SOURCE: Hi I had a paper jam in my MFC 8820d - I removed
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Posted on Sep 02, 2009
Can't clear 01 fuser jam
open top scanner, open inner cover where printed paper normally comes out. push left and right locks on the fuser and the fuser will come out. remove jammed paper. put back together in revers order. paper jamming in the fuser is a sign the fuser is faulty/worn o non genuine toner is being used.
Feb 08, 2011 | Samsung CLX6220FX COLMON MFC Printer
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
Comes up with paper jam. Open cover, remove drum and removed jammed paper. Had a look no jammed paper, looked at the back fuser area, no jammed paper. Removed paper try, no jammed papper. Can u help
If your printter is showing the message even after you have made sure that there is no paper inside the rollers , it is sure that the sensors- optocouplers- or the input amps for the sensors are defective. Youmay need to check on these individually to confirm. Identify them justt placed beneath the rollers take in guides. Check if thedetector is emitting even without the paper. use a multimeter to check of rvariation of votage with paper or without paper to confirm. hope you try this out and confirm. Good day,
Aug 11, 2010 | Brother MFC-8460N All-In-One Printer
Paper jammed at this time error message show on control panel 13.05.00-Jam in top cover area open front covers and Transfer unit. Fuser is hot transfer unit can be easily damaged. Check left side of...
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Jul 14, 2010 | HP LaserJet M4345 MultiFunction Printer
Paper jam
This is a very easy fix.
  • First, open the front cover.
  • Next pull out the black thing that is right there.
  • The cartridge is inside of the drum, and the drum is what you need to pull out.
So basically, when you open the front cover, you need to pull out the thing you see, and you need to pull it upwards for it to come out. The paper should be under it or behind. Hope this helps! If you need pictures, just email me-eran_4h@hotmail.com. GOOD LUCK!
Feb 01, 2010 | Brother MFC-7440N Laser Printer
202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Mar 06, 2009 | Lexmark T632 Laser Printer
What is media jam fuser error
It means there is a paper jam in the fuser (the hot part that fixes the toner to the paper).
Check if there is any sheet jammed inside your printer or if any sensor is in the wrong position.
If everything seems to be ok, you may need to replace the fuser.
Nov 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Paper Jam with no access to clear
you will need to remove the fuser module from the machine and open the fuser to remove the wrinkeled paper inside the fuser section. then reinstall the duser in the reverse way
Jun 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
Nov 29, 2007 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC-7440N Laser Printer Logo
433 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
