Question about Sunbeam Steam Master 4220 Iron with Auto Shut-off
Auto shutoff does not turn the heat on. . .how to remove the rear cover plate?
My Black & Decker d2020 iron immediately goes to auto shut off and will not stay on.
test the 1) fuse heat and replace it
2) test the board if there are voltage , if there are the board can be faulty or repair.
3) see your instruc. manual go to the section troubleshooting and see what is wrong.
God bless you
Sep 30, 2012 | Black & Decker D2020 Iron
How to clean
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Aug 22, 2011 | Rowenta DW9080 Iron with Auto Shutoff
I need the instructions to clean the iron, please. I lost my manual. Thanks!
heatman101
Apr 02, 2011 | Sunbeam 4232 Iron with Auto Shutoff
My Conair Proshine Straightner won't warm up, although the light is on. How do I fix this? ... hot plates not heating and the light says its warming up but the hot plates won't heat up
Most heated hair appliances are protected by a thermistor that will fail if overheated. These are small, about 1/2" long, cylindrical in shape with a pointy end and a wire coming from each end. When they go bad, they do not conduct electricity (zero ohms on a meter). There is a three digit number on the side that is the shutoff temperature. You can get these at Radio Shack.
Don't bypass this safety device.
Jan 07, 2011 | Conair Professional Ceramic Hair...
Not heating element
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Iron not Heating Up or not Working Right
heatman101
Dec 19, 2010 | Morphy Richards 40710 Iron with Auto...
Iron switches on but does not heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 07, 2010 | Russell Hobbs 12236 Iron with Auto Shutoff
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 06, 2009 | Rowenta Professional Luxe DM880 Iron
My rowenta effective will not heat up.
Dec 15, 2008 | Rowenta DG5030 Iron
Sunbeam Steam Master 4220 Iron with Auto Shut-off Logo
24 people viewed this question
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
