Question about Kenmore Dishwashers
I have a Kenmore dishwasher (model 363.14478791). I hadn't used the dishwasher in a month. I turned on the dishwasher tonight and noticed nothing was happening, but I was getting a clicking sound. I moved the dial to the right to off. As I moved the dial to the right, there were lots of clicks and clunks. I started over and turned the dial to the start position. Some water went in, but then nothing happened again. I clicked forward one click at a time. Sometimes water came in. Then water started pouring onto the foor, so I moved the dial to the right and back to off. After water stopped leaking, I opened the door. There is still water in the bottom and heat in the dishwasher.
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: I turned on the dishwasher tonight and noticed
Hi
Thanks for using FixYa. As the water is not draining and clicking is coming from the bottom so the issue seems to be with the drain pump solenoid.
Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
My kenmore elite dishwasher is brand new but tonight it is flashing locked and I can't get it to do anything
Some times just turning off the power for a few minutes will reset the program--if not, in your instructions you should find what the flashing light is an indicator of--
Jul 14, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher does not start
I had this problem and solved it by merely switching the associated circuit breaker off and on again. Something of a "hard reboot." Annoying ... and ... if it happens repeatedly (tonight was the first time), someting I will pursue fixing while hte d/w is still under warrwentey (It was purchased/installed less than three months ago.)
Dec 12, 2012 | Kenmore 18" Built-In Dishwasher -...
Kenmore dishwasher wont turn on seems to have no power.
Check the breaker in your breaker box, it may have tripped. Reset it and run the dishwasher. If it trips again, have the dishwasher looked at by a professional service person.
Feb 13, 2012 | Kenmore Dishwashers
Kenmore model 6651701 arms are not moving, water has no pressure to move arms what is the problem, is there a motor, filter?
water is sprayed up a cylinder to the arms which usually spin you may be able to lift the arm off and check the oulet holes for clogs if this is the problem clean them out and purcase a bottle of dishwasher cleaner use it on wash cycle at least once a month.just place the bottle upside down in the metal utensil tray in the bottom of the dishwasher make sure there is nothing else in the machine and make sure that the water is hot by turning on the hot water tap before you start the cycle,,,Cleaner also has instructions on the label avaiable atanystore that sells your diswwasher soap
Dec 16, 2009 | Kenmore Dishwashers
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
Sep 26, 2009 | LG LDF6920ST Stainless Steel 24 in....
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
43 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
