Question about Canon imageRUNNER 3225 Black and White Copier
Having problem in canon ir3225, giving error code e000005-00 immediate after switching on the machine. solution required immediately.
My cannon gives error code E000280-001 please help.
Posted on Mar 28, 2011
  • ratul dutta
    ratul dutta Jan 30, 2017
    chage the ccd white flat cable
  • Suhel Khan
    Suhel Khan May 03, 2017
    Cnnon ir 3245 hai cood 00225_0001 ah raha hai keya problem hai
Error 5040 in canon maxify 2340
If you wish to get some details about printer repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 25, 2016 | Canon Office Equipment & Supplies
Canon iR3225 is giving error code E000007-0000
there is a problem with the fuser fixing film...
you may follow the following procedures;
1. clean and re-oil the fuser fixing film, and
2. if the error persists, consider replacing the fuser fixing film
thanks
Mar 10, 2015 | Canon Office Equipment & Supplies
Www.ir 0227 error code what is the problem
Hi
The webpage here:-
Error Codes Canon iR3225 page 3
gives a whole list of error codes, 16 pages in all, but your code I think is on this the third page. Each code can be looked at individually and you can also, for a small charge get a Service Manual (pdf format) for future reference.
Use the arrows at the top of the error list to navigate forwards or backwards through the pages.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 11, 2015 | Canon imageRUNNER 3225 Black and White...
Notes on error 030 on canon np 6317
Hi
This error code refers to "Total counter disconnected or open" but doesn't give an immediate solution (one assumes reconnection would clear it.) The page can be found here:
Error Codes Canon NP6317 Code E030
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Dec 17, 2014 | Canon NP 6317 COPIER FOR 220 VOLTS ONLY
How to fix NG in the log list of canon ir3225 that prevent it from printing document from pc
there was no code after NG.The print command is working from the pc but the canon machine ir3225 on the log list it shows the job no and all but in the result section it shows NG without any code.This Makes me headache ,please can any one solve this
May 23, 2014 | Canon imageRUNNER 3225 Black and White...
Inherited this 2200 w/ new political office. Was working fine and making clear copies - then error code E000000-0000. Restarted machine - tried Press * Press 2 Press 8 Press * - got nothing. Help.
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
Feb 03, 2011 | Canon imageRUNNER 2200
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Jun 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
Canon imageRUNNER 3225 Black and White Copier Logo
689 people viewed this question
old marine
old marine
