Question about Intel Acbel Power Supply 400W/450W Supports ATX 12V v2.0/ EPS 12V v2.1/AMD ATX-GES (PSACBEL) Power Supply
Have a ACBEL API 7650 power supply but don't knoe to wire it to get out the supply power
How to make a pc power unit work without a motherboard?
There are two pins on the atx connector you need to bridge. You can wire a switch to the pins too if you want so you can toggle on and off. Otherwise, there is a guy on eBay (seller id: antronst) that sells a connector with the pins already bridged with a on/off switch and a resistor wired in to provide some stability for five or six dollars.
Here is a diagram. Make sure it is a standard atx power supply. Some old Dells had goofy wiring.
http://www.techpowerup.com/articles/other/22
May 16, 2014 | Intel Acbel Power Supply Supports ATX 12V...
Want to replace API-7506 power supply. Is there an equivalent available in Canada
Pull the old one out and go down to Futureshop. Any brand will do as long as:
1. the connectors are the same type
2. the physical size will fit in your case
3. the wattage is the same or more than 330W
The are available several places in Canada and it doesn't need to be IBM.
Feb 22, 2011 | Dell API-7506 IBM 330W POWER SUPPLY...
Have a ACBEL API 7650 power supply and need to know how to wire it in fore all the different voltages
What do you mean wire it in for all the voltages? What are you installing it in to?
Please let me know the make / model of machine or board you are trying to attach it to and I can help.
Thanks
Tim
Oct 07, 2010 | Computers & Internet
I need a replacement ac adapter, acbel model AP13AD05 for Javelin POS Terminal.
hello.
You can visite our website and we can supply you the replacement adapter.
www.vtronicstech.com
Michelle
goo.michelle@yahoo.com
skype: michellegoo
Jun 16, 2010 | Javelin Systems Inc (81160083W98) PC...
I have a CRT monitor hp 7650 and i have a problem that monitor power supply not working
I hate to sound nasty but these days it would be cheaper to buy a used but working CRT monitor than try to get one repaired. I've seen 22inch CRT's going for $10. Nobody wants them now there's LCD and LED monitors.
If you are really set on getting yours repaired, try Ebay. You may have to wait a few weeks for your specific model to come up but it could even be available right now. It may even be better to ask the seller to pull the power supply for you and just send it to save on freight.
Strange it's the exact model name for a scanjet too.
Good Luck
Apr 24, 2010 | HP Computers & Internet
Power supply for mac g4 model AcBel api 9841 is  not swich on
I'm not sure exactly what you mean by "is not swich on" but I'm assuming your G4 will not turn on when you press the power button. You most likely have a bad power supply. If you want to make sure it is the power supply and are comfortable using a multimeter and following a few instructions then I've included a link below to an Apple knowledge base document explaining how to test a power supply.
How to test the power supply
WARNING: You will be working with live power. Take caution to follow the directions exactly and pay attention to where your placing your leads.
Hope this helps, don't forget to leave feedback if you found this helpful.
Feb 18, 2010 | Apple Computers & Internet
Scanner showing error 04 and cant let me scan
Disconnect the power supply from the back of the scanner base.
Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
Reconnect the power supply and turn on the scanner.
Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
now try to scan the document ..........
Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
The model is actually discontinued now, but you can download Driver Software and a Manual for the Scanjet 7650 from the HP website:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=uk&prodTypeId=15179&prodSeriesId=434502&lang=en&cc=uk
You can also get Parts information.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | HP ScanJet 7650 Flatbed Scanner
Apple g4 digital audio Power supply API-9841
Solution: Replace power supply with a new one. Anything else might cause equipment damage, personal injury or death.
Any attempt for component level repair is not for the novice tinkerer. remember, opening the power supply might kill you.
My suggestion is to have the failed power supply module replaced with a brand new supply by a qualified repair technician.
Jul 24, 2008 | Apple G5 Case with Power Supply (p/n...
Intel Acbel Power Supply 400W/450W Supports ATX 12V v2.0/ EPS 12V v2.1/AMD ATX-GES (PSACBEL) Power Supply Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
