Question about Zenith ZEN760 Remote Control
Zenith Learning Remote
Inherited one of these without any instructions. What is the procedure or process for programming the remote for you individual TV with built in VCR. One code should work for both, but how to find the one code? The TV is a Sanyo, but my concern is the procedure-process for programming.
  • oberfeldwebe May 30, 2008
    Serching the web found the answer to my own question
    FINALLY !
    This method worked Excellent ! Try it, be patient and take you time, take maybe two minutes or so, less or bit more on the search.
    The only problem I have found thus far is it will display the menu but not let you use it, still working on that aspect.
    Programming Zenith Zen 960 A Remote
    Method without the code list)
    1. Manually turn on the device you wish to program.
    2. Press and hold the CODE SEARCH button until the indicator light turns on and stays on. Release the CODE SEARCH button.
    3. Press the appropriate device button (TV, VCR, CABLE, DVD, or AUX) The indicator light will blink again and remain on.
    4. Press the POWER button repeatedly until the device shuts off. This may take up to 300 tries, so don't go too fast or you might skip over the one you need. If you do skip over a code, press the CHANNEL DOWN button to back up.
    5. Press the MUTE button to complete setup.
  • Anonymous May 09, 2009
    The Zenith ZEN-760 remote pictured does not have a MUTE button. (step 6)
    Problem Solver:
  • 7 Answers
I am looking for the White Westinghouse sk26h240s remote codes for a Comcast universal DVR Remote control. any ideas, please email me at renee.walton@comcast.net.
Posted on May 30, 2008
THANKS A BUNCH. I had this control for some years now.....
and it still works.
It took like less then a minute to get it to work.
Posted on Oct 07, 2008
AWESOME! this worked in less than 3 minutes!!!!
Posted on Jul 09, 2008
Does anyone have the user manual for Zenith universal remote control model number ZNLCD7?
If you wish to get more details, check the sites linked here. It has set-up code list, and set-up procedure to many popular brand remote controls. Surf the sites with patience.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Oct 19, 2014 | Zenith ZNLCD7 - 7 Device Universal...
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
Replaced battery on my remote control and it does not work. does it needs to be re-programmed again?
Use this Procedure for Vehicles with
Driver Information Center Buttons
This information is in your Owners Manual in the
Drivers Information Center Section.
1. Insert Key and turn to ON position so you can access Driver Information Center
2. Press the vehicle information button until
PRESS TO RELEARN REMOTE KEY displays
3. Press the set/reset button until
REMOTE KEY LEARNING ACTIVE displays
4. Press and hold the lock and unlock buttons on the first keyless remote at the same
time for approximatley 15 seconds. A chime will sound indicating that the remote is
programmed.
5. To program additional remotes at this time repeat step 3.
This vehicle can have a maximum of eight remotes programmed.
6. To exit programming mode turn key off and remove key.
Test remote(s).
Use this Procedure for Vehicles without
Drivers Information Center Buttons
To access this display, the vehicle must be in Park (P) with key in the on position (as far
as you can go without cranking engine)
1. Press the trip odometer reset stem until RELEARN REMOTE KEY displays.
2. Press and hold the trip odometer reset stem for three seconds.
The message REMOTE KEY LEARNING ACTIVE will display
3. Press and hold the lock and unlock buttons on the first keyless remote at the same
time for approximately 15 seconds. A chime
programmed.
4. To program additional remotes at this time repeat step 3.
5. To exit programming mode turn key off and remove key.
Test remote(s).
Good luck and hope this helps, you may have to reprogram. merry Xmas
Dec 24, 2009 | 2007 Chevrolet Tahoe
I need codes
Hi stimmdua,
There are a number of codes for your remote that work with Zenith TV models. They are:
002 008 115 215 405 407 601 701 713 903 916
For your reference, here is a web address that includes all the codes for your remote, along with programming instructions:
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Philips Magnavox Learning Universal Remote
I got a ZN110 remote control wit a Zenith Tv and it does not work?
It doesnt look like anybody has the programming instructions for this remote. I found one just like it called the RRUNV. go here to see details. It does come with instructions on how to program. http://www.replacementremotes.com/store/productdetailp.cfm?productid=60267
May 26, 2008 | Zenith ZN110 Remote Control
Zenith zn-bb5 remote.
I believe you hold down the setup button until the light stays lit, hit the companent button (tv) enter the code and the led light should flash 3 times.
Feb 23, 2007 | Zenith ZN-BB5 Remote Control
Zenith ZEN760 Remote Control Logo
783 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
