Question about HP 32sII Calculator
THE 9 6 AND 3 KEYS ON MY HP 32S11 JUST STOPPED WORKING. WHEN YOU TOUCH THE KEY IT REMAINS ON ZERO
2 Suggested Answers
  • 77 Answers
SOURCE: Changed batteries, zeros are in display but no key response
Perhaps a the connections are dirty (battery connections) or you may have the wrong battery type/model
Posted on Feb 11, 2009
Dryer soft touch key pad not working
re install driver for this key pad
Apr 14, 2014 | HP Computers & Internet
Hp officecalc 100
As a get around, use the double zero key then back delete one.
Mar 06, 2014 | HP Computers & Internet
My hp laptop touch mouse pad has stop working
Ensure that you have not accidently disabled it check your function keys for a picture of a mouse with a line through it then hold the function key and that button at the same time.
Sep 04, 2011 | Computers & Internet
My Hp Laptop's touch pad is not reponding to touch. Please help me. The curser reponds but not the touch reponse. The touch pad reaponds to scrolling but not to finger tappings. The two right and left bars...
there is a key combination that enables/disables the touch pad. it's the Fn key + the function key that shows a little mouse icon in blue at the top of your keyboard. on Fujitsu this would be Fn+F6 for instance. if this doesn't work, it is possible that the touch pad has been turned off in the BIOS setup. you will have to enter the BIOS and enable or automate the "internal pointing device"
Apr 21, 2010 | HP Pavilion dv6000z Notebook
I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Zero wireless configuration has been disabled on presario
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
Jul 29, 2009 | HP Computers & Internet
Error46
press the menu and mono start keys next pess the arrow up key 4 times to make machine enter matinence mode
2 enter 8 and 0 by using arrow key and set key
3 press mono start key several times until the purge count appears on the lcd
4 ente 2 7 8 3 by using arrow key and set key to reset the purge counter to zero
5 press stop/exit key and return to the intial stage of mantince mode
6 enter 9 twicw by using the up arrows and set keys to exit from matince mode
Jul 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp laptop touchpad for cd and wireless conet. stopped working
I get it. The multimedia keys above the keyboard is not working. If I'm right, check if you have installed the HP Quick Launch buttons software. If not check in C:/SwSetup and you'll find a folder. Install the application and check if the buttons are working. If not, post back
Jun 24, 2009 | HP Pavilion dv4000 Notebook
Configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Nov 19, 2008 | HP Jetdirect J2552A/B (J2552AB) Print...
HP 32sII Calculator Logo
56 people viewed this question
Seeker5211
Seeker5211
