Question about Dishwashers
How do I remove the soap dispenser from a GE Profile PDW7980N dishwasher. The reservoir is leaking. I have taken the panel apart, but the reservoir is held on by a ring that the cap screws into. Does the ring screw off or pop off?
  • bparker4444 Oct 08, 2010
    The last advice did not answer my question. I have a GE Profile dishwasher, PDW7980N that has a "Smart Dispenser" soap dispenser. Not the one with the little flip lid (although it has that too, but it's not the problem), but one you unscrew a cap, fill it up with soap and you don't have to add soap each time you wash. Mine is leaking soap inside the front door cavity and I believe the reseviour is cracked. The only thing holding the reseviour in place is the threaded ring that you screw the dispenser cap onto. I need to know how to remove that ring. Is it threaded on as well? Does it snap off?
  • bparker4444 Oct 09, 2010
    Yes, this is exactly what I needed. Thank you.
  • 19,396 Answers
Hi.
To remove the smart dispenser, remove the door panel first.
How do I remove the - moz-screenshot-1.pngThe outer door panel is secured by twelve screws, this are 5 Phillips head screws on each side and two 1/4-in. hex scresw at the bottom:
Unless needed, becareful NOT to remove the set of 4 screws (2 per side) holding the escutcheon to the door assembly. These screws are removed only in case you need to gain access to the control module, active vent, ? apper, and door interlock switch. Screws indicated below should not need removat to access the dispenser assembly:
Insert a small ?at tipped screwdriver into the slot in the side of the retaining collar and turn the screwdriver handle counterclockwise while turning the reservoir access collar counterclockwise a quarter turn. Remove the retaining collar. Unplug the tube from the reservoir outlet and then disconnect the sensor wring from the cHow do I remove the - 9a7bee0.jpgle:
The smart dispenser plastic collar cannot be removed without damage. The collar Must alwyas been replaced when you disassemble the dispenser. (See door parts for this model here).
Here a schematic diagram, of the door click on the picture to enlarge.
To get all parts and diagrams, click on link below and enter the model number:
Sears parts.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips takes time and requires skills and practice. Your feedback is important for us.
Regards.
Ginko
Posted on Oct 08, 2010
  • Ginko
    Ginko Oct 08, 2010
    Hi.
    Did you receive my instructions?
    Please let me know if you need further info. If the solution was helpful, then please do not forget to accept.
    Best regards.
    Ginko.
    Brigadier General:
  • 3,513 Answers
Please check the bellow link related to your issue:-
http://www.ehow.com/how_5055396_fix-soap-dispenser-not-open.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Why does it keep dispensing soap?
What do you mean "keep dispensing soap"? Is this a GE dishwasher with an automatic soap dispenser? Or do you mean that the soap lid won't latch or stay closed? Or are you talking about the rinse-aid dispenser leaking rinse-aid (which is fairly common)?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 11, 2015 | Dishwashers
My GE Potscrubber Model GSD2230Z04WW is not dissolving the soap. I have already replaced the water inlet valve.
Check your wash arms, and make sure the holes are not plugged. Also make sure they are free to turn. Next,remove the toe-kick panel, and look for leaks or signs of leakage. Sometimes (especially if your tile floor doesn't go all the way back), dishwashers will leak most of their water out and you never know it! Other simpler things is to make sure you are not blocking the soap dispenser with large pans or plates.
Feb 17, 2015 | GE Dishwashers
Ge potscrubber 700 dishwasher - the soap dispenser cover is locked and will not open. I have run the dishwasher several times and tried to force it but it will not budge. any suggestions?
Soap dispenser cover will not open until front knob is at 4:30 or 5 o'clock. Turn knob to 5 o'clock and jiggle dispenser cover. If cover still does not open, is detergent caked such that door won't open? If yes, remove caked detergent. If no, disconnect power at breaker. GE repair manual says to remove screws for inner door panel and inspect detergent dispenser mechanism with lever and trip lever for broken or binding parts.
Oct 13, 2013 | GE Dishwashers
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
I put liquid dishwashing soap IN THE RINSE AGENT DISPENSER. What can I do?
I suggest purchasing a pipette (long thin flexible plastic eyedropper thing) from hobby lobby, Frye's, or from a scientific lab supply.
Draw up as much a you can from inside. Apart from that unless you remove the panels from the door to access the reservoir, then it may take several more washes to remove the soap from the the rinse additive dispenser. One more thing, you could start the machine in the rinse mode to wash the dishes and stop it when done and restart in the wash mode to rinse. When that is finished, stop and restart in the drying cycle. Good Luck!
Jul 03, 2009 | Dishwashers
GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Apr 06, 2009 | Dishwashers
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
Dec 21, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 04, 2008 | GE 24 in. Profile PDW7800 Built-in...
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
232 people viewed this question
Top Dishwashers Experts
