Posted on Oct 08, 2010
My Brother printer HL-2170W is putting black marks on the printed paper. How do I clean the printer to stop this?
4 Related Answers
Joed911
JDTec
  • 4338 Answers
  • Posted on Nov 30, 2008
SOURCE: Corona wire problems
Read the following links:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000026/faq002526_000.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000008/faq000208_021.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • Posted on May 21, 2009
SOURCE: Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at [email protected] should you have further questions.
Anonymous
  • 59 Answers
  • Posted on Mar 26, 2010
SOURCE: How to clean brother HL-2170W drum (DR-360)
reve the toner and drum from the machine, seperate the and put the toner aside. slide the tab back and forth about 20 times then blow in the slot. if you need to you can wipe the roller with a clean dry cloth.
Anonymous
  • 405 Answers
  • Posted on Apr 03, 2010
SOURCE: Got a paper jammed in my brother hl-2170w
Open the front cover of Printer, remove the drum and toner with force and put aside. Remove the jammed paper slowly so it doesnt rip. If you cannot find the jammed paper check in the back cover and paper tray.
My brother HL-2170W have a flashing error and drum light. When the printer starts up, its stops in the middle as if a paper is stuck but I can't find anything.
Hi There,
The Drum LED and the Error LED alternates turning on and off.
Meaning of LED Indication
Drum error:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Please click on YES if this helps,
Thanks,
Vikroks
PAPER JAM WON'T PRINT
Try to check the message where is the JAMMED PAPER located, Brother printers display the message exactly.
Then remove the jammed paper from the printer.
Then switch off your printer and Turn it off again..
this will work
Hl 2170w How do you get the paper out if you have a paper jam.
read page 85 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf
Top marging changing (HL 2170W)
try cleaning the feed roller above the paper tray.. but if you have problem when the image is getting lower, it means your paper feed faster than the image trans, I would suspect the feed solenoid is giving you the problem..as it's not release on time... to fix it, you will need to open the whole printer cover and side motor assy..
2helpful
Paper jam in printer. Error light blinking.Can't get paper out
Turn the printer off, Open the front cover where the drum and toner are installed. Remove the drum and toner (cartridge). look inside the machine for a paper jam, also open the back cover and check there.
9helpful
4helpful
Norman Weimar
Norman Weimar
k24674
