Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Does anyone know where I can get the 9 tooth chain sprocket (not the one on the unit) for a Doorman 455?
    President:
  • 3,197 Answers
If you are looking for the sprocket that goes on the door end of the T-rail you can call any Chamberlain or Liftmaster dealer in the yellow pages. They might even sell you a used one off an old opener they have changed out.
Posted on Oct 08, 2010
I need to know the size of the center hole on a 19 tooth transmission sprocket for an apc mini chopper Thanks
Why do you need to know the size of the centre hole. That one look in great condition. The size is the size of the shaft it fits on, so you measure the narrower distance, which is between the sprocket tooth that is under the middle of your thumb nail, to the second tooth past your index finger. All this links have info.
  • mini chopper sprockets ' eBay www.ebay.com > Search > mini chopper sprockets Refine your search for mini chopper sprockets. ... Mini Chopper Pocket Bike Parts 19 Tooth Front ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ...
  • mini chopper sprocket in Parts & Accessories ' eBay www.ebay.com > Search > mini chopper sprocket Find mini chopper sprocket from a vast selection of ... Mini Chopper Pocket Bike Parts 19 Tooth Front Chain Sprocket ... APC MINI CHOPPER 48" THROTTLE CABLE ...
  • I need to know the size of the center hole on a 19 tooth ... www.fixya.com > Forum > Motorcycles > APC ... a 19 tooth transmission sprocket for an apc mini ... on a 19 tooth transmission sprocket for an apc ... rear 28 tooth sprocket for an apc mini chopper.I ...
  • Mini Chopper Sprocket and Clutch - DIY Go Karts www.diygokarts.com/chopper-plans/drive-assembly.html ... a torque converter can be used which effectively gives the project an automatic transmission. ... mini-chopper's clutch ... tooth #35 pitch. This size sprocket ...
  • mini chopper parts ' eBay www.ebay.ca > Search > mini chopper parts mini chopper parts 352 listings. ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ... #428 Chain 17 Tooth 14mm Pitch Sprocket Part Gear Go Kart ...
  • Sprockets - PartsForScooters www.partsforscooters.com/Pocket-Bikes-Parts/Pocket-Bikes-Sprocket Mini-Chopper Parts; ... 127-19 . Stock 6 Tooth Front Sprocket with M10x1.00 thread size for 47 and 49cc 2-stroke cag style pocket bikes and mini-quads.
  • Mini Chopper Parts ' Mini Bike Parts ' We Ship https://www.gokartsupply.com/chopper.htm Home >> Parts Catalog> Mini-Chopper Parts. Parts For Mini Choppers Seats - Hand Controls - Fenders. ... SPROCKET 60T #35. 7-1/4" 28.50. 04-470. SPROCKET 72T ...
  • Electra / APC Mini Chopper w 49cc PS engine - Pocket Bike ... www.pocketbikeplanet.com/showthread.php?t=84442
    • 20 POSTS
    • FIRST POST: 2014-06-29
    2014-07-26 · Electra / APC Mini Chopper w 49cc PS engine Mini Choppers. ... Sounds like you got a transmission with slag on the internal gears ... do a search as mini chopper parts.
  • mini chopper bike ' eBay www.ebay.ca > Search > mini chopper bike Find great deals on eBay for mini chopper bike and ... 43CC 49CC APC MINI CHOPPER MINI BIKE MONKEY ... 17 tooth sprocket gear Pocket Bike Mini Chopper ...
  • Rawge's Mini Chopper Information Site - Gearing and Sprockets www.rawge.bravepages.com/minichoppers/speedo.htm Rawge's Mini Choppers ... The Simple Mini Chopper Drive ... you can expect from your mini chopper, given the size of the sprocket on your ...
  • Pagination
  • Apr 08, 2016 | APC Motorcycles
    Why doe my sprocket on Husqvarna 455 keep tearing up the drive part of he chain
    Are you sure the pitch of the chain is the same as the sprocket, ie if you are running a 3/8 pitch chain you need a 3/8 sprocket, if this is correct then you need to address your chain tention and sharpening.
    Aug 18, 2013 | Husqvarna Chain Saw 20" Bar
    I can't get my chaing to stay at a normal tension. it either gets too tight or too loose! is this a common problem? perhaps a defect? or whats the solution
    assuming you have the chain adjuster in the bar adjuster hole. This and the bar nuts will normally keep the bar in place and the chain adjusted. However if your drive sprocket on your saw is worn (deep grooves where the chain rides on the sprocket) it will cause the chain to try and climb over one tooth pulling the bar toward the saw loosening the chain. This can also happen if you put a worn chain on a new sprocket. In the end this overtight or loose condition will lead to failure of your sprocket nose bar. One other way can be the chain, the bar and the sprocket are not all the same pitch.
    Oct 13, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
    How do you rePlace the chain on the 455 rancher?
    You take the chain cover off of the bar. It is two nuts. Take them off and the cover will come off. Slide the bar toward you and the chain will become slack. You can then slide off the chain from the sprocket. To put a new one on. You will need to turn the chain adjustment back all the way to the left. Then put the chain back over the sprocket, then onto the bar. Put the chain cover back on and tighten the chain back up. Then tighten the two nuts back to tight.
    Apr 03, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
    After new clutch sprocket &good bar &chain chain r bar moves prematuely and chain comes off bar nuts r tight
    have you made sure that chain pitch and gauge are the same as the sprocket pitch pitches can be 3/8 lo pro 0.50 gauge
    .325 x 0.50 gauge , .325 x 0.58 gauge
    3/8 std x 0.50 or 3/8 x 0.58 gauge or 3/8 x 0.63 gauge
    you could even have the correct drum but wrong rim sprocket on it
    worst case is you could have mismatch bar and chain
    make sure that bar adjjuster assy is working correctly
    recheck chain / sprocket pitches and bar pitch and groove
    gauge
    be sure that you fitted chain to rim on sprocket correctly when you fitted bar and chain?
    is the clutch cover pulling down tight ?
    have a look and let me know if and what you find
    cheers paul
    Aug 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
    Automatic Doorman model 455 learn button location?
    The button should be on the back of the motor unit. You may have to remove a light lens to find it.
    Aug 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Can i change my front sprocket on my kawasaki w650 from 15 tooth to 16 tooth and what would be the consequences
    you need to change the rear also the chain teeth are for a 15 tooth so get ready to change your chain also
    Aug 04, 2009 | 2001 kawasaki ZX-9 R Ninja
    Chain adjustment question
    Well i dont think the ride hieght will change, nothing you could notice, and if your changing sprockets its best to do both and a new chain, now i might add that it is preffered to change chain with sprockets not required if the sprockets are ok. As to the length i can only say i run the 17 tooth around the city and for the long trips i swap back to the 18, mind you it is a new 18 not the original, of course with the change back (2nd time) i have not changed the chain and have been running the same chain length, it has shortened the wheel base from the original 18 tooth front, but i kinda like it a little shorter, gives me more weight over it and the front gives more feed back, but thats just me, not saying its right
    Nov 10, 2008 | 2005 Triumph Daytona 955i
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    129 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
