THE BATTERY CANNOT CHARGING, WHEN REMOVED THE STAB OR UNPLUGGED THE LAPTOP IS BLACKOUT OR MISSING
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 08, 2010
Plugged in,not charging
I think your battery is faulty. Not charging anymore has reached his lifetime. Replace the battery.
Mar 14, 2014 | Acer Aspire Computers & Internet
Laptop dies when unplugged
Panasonic Toughbook PC Laptops usually have
very reliable battery pack. When your unit is plugged-in
but the Power is OFF, you should see an LED light as follows:
RED FLASHING: Means the battery needs replacement.
Orange/Yellow Solid: Means battery is charging.
Solid Green: Means battery is fully charged.
NO Light AT ALL: Means that Battery Pack is missing.
There is also a battery calibration utility on all Panasonic
Toughbook PC's manufactured since 2004. This is a factory
installed software and is only present in factory units.
This software may also be downloaded as a driver from the
Panasonic Toughbook website as follows:
http://pc-dl.panasonic.co.jp/dl/
Check also in the bottom right hand corner under
Windows for the battery Icon. This will indicate if
the battery is charging, present or not present,
and under Windows 7+ will indicate if the battery
needs to be replaced or not.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 01, 2013 | Panasonic Toughbook Computers & Internet
My acer Aspire 4741 laptop does not charge its battery. that is why every time i use it, it is plugged in. what could be the problem?
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
In some situations the battery can become loose. Removing it and then put it back into the laptop.
To remove the battery slide this switch to the opposite side and hold it in that position until the battery is removed. When doing this with some laptops the battery will pop out and allow you to grab onto it. Others will release the latch and require you to grab onto the battery usually with the tips of your fingers and pull it out.
In most cases this will help, but if the problem persist you may have to get a new battery for your laptop.
Good luck
Aug 27, 2011 | Computers & Internet
Ibought my asus laptop yesterday it has been on charge over nihght this morning i turned it on but the screen is blank please can you help me
Charging the battery overnight may cause an overcharging. You may remove the battery using the right lever or switch at the back of the laptop. After a while, re-install the battery again, then try to power up. If it is still blackout, return the unit to your reseller, it's under warranty and they may just replace the unit or repair it for free.
Good luck.
TedMac
Sep 16, 2010 | ASUS Computers & Internet
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
Laptop turns off as soon as power cord is removed. I was in the library last night and had it plugged in for awhile. When I went to leave I unplugged it from the wall and the whole computer just *******....
It appears that the battery is not charging. Simply reseat the battery, remove it and put it back, If its still not charging, you may try a another battery. If the other battery is still not charging, you may have to call your laptop manufacturer for motherboard replacement. Hope this will help you.
Regards,
Mel
Feb 24, 2010 | Computers & Internet
AC Power and Battery Problem.....
Sounds like the battery or possibly the charging circits themselves are the problem. Can you try turning on the laptop with just the power cord in and no battery?
Aug 20, 2008 | Compaq NC8000 Notebook
Computers & Internet Logo
David Payne
David Payne
