Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
Kenmore 35913 Progressive Vacuum with Direct Drive
How do I hit the reset button? When I hit mine, nothing happens. Thanks a bunch.
  • preese Jun 19, 2008
    reset doesn't even push in...it stays put....now what? get a new, throw it out the window? Use it as a coat rack? Desperate.....do NOT want to get another vacuum, but if I have to I have to....
  • Anonymous Dec 31, 2008
    Don't want to pay for answer, Mother in law has an upright vacuum; Kenmore from Sears. light comes on but motor doesn't run. Is there any reset somewhere I don't know about? John
    President:
  • 1,673 Answers
If you push the reset, it should push in and if nothing happens, then there is a problem with either your cord, switshes or motor.
Posted on Jun 01, 2008
Everything seems to be working fine except it has no suction. I changed the bag and filter, but still nothing.
Probaly a clogged suction tube, unplug the vacuum first then tilt the vacuum upside down and see if you can see a clog .On the back side of the brush it will be kinda funnel shaped and that leads to your suction tube . That is the most common place for a clog.
Rate my answer with the thumbs..........Thanks
Dec 03, 2010 | Kenmore 35912 / 35913 Progressive Upright...
The suction doesn't work. what can i do
I changed the two filters on mine and pressed the reset button and that worked.
Oct 17, 2010 | Kenmore 31912 Progressive Direct Drive...
The brush is not rotating
Try pushing the reset button with a pen or paper clip. If that doesn't work, the motor may need to replaced. If the reset button is stuck, I don't know how to fix it - mine has the same problem.
Feb 21, 2010 | Kenmore 31913 Progressive Direct Drive...
Brush won't turn
The Agitator Overload switch is located on the top of the base assembly. Unplug the vacuum and press the reset button. The vacuum also has thermal protection, which will reset itself once the vacuum cools. The agitator will also stop when the vacuum is in the full upright position.
35922 Owner Manual
Feb 08, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore progressive/direct drive-- roller stopped turning
We have the same vacuum & had the same problem. As the vacuum ages & the hose is periodically removed from the nozzle to use with the attachments, the white switch, adjacent to the nozzle connection, wears. If the hose is not fully reinserted or if the attachment notches are inadvertently aligned with the white stitch, the agitator may not work reliably. Assuring the hose is fully inserted, with the locking notches away from the switch has eliminated this problem with our vacuum cleaner.
Jan 24, 2009 | Kenmore 31913 Progressive Direct Drive...
Go to sears.com, click on the parts link, enter your full model number, then scroll down and there are several options to clikc on, a parts list and picture parts breakdown are there and if a manual is available, you can get it and parts thru this site. There is a overload switch for the brush roll motor, if tripped then it won't turn. Could be that the brush roll motor is bad. The motor and brush roll are put together as one unit, but you can get the motor by itself.
May 29, 2008 | Kenmore 31913 Progressive Direct Drive...
Direct Drive System on Kenmore 31913 Vacuum
you need to reset it on the front. overload reset button
Oct 29, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
My vacuum is not sucking at all.....
I took out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared. Then I put the filter back in and it works perfectly! Barb
Mar 01, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
256 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
