Question about Kenmore 53701 Dehumidifier
The dehumidifier just suddenly died. We've had it for three years and only use it about five months out of the year. Is it even worth fixing, as it wasn't that expensive...
My dehimidifier get electricity, but will not run. What shuold I do other than to take it to Sears?
Posted on May 18, 2011
The display cannot be seen, as the blue background light has slowly went dim.
10 years is not quick in my book 2 weeks might be and I have seen LEDs die in less than a month .
Jul 11, 2015 | Dehumidifiers
A bypass to well no longer occurs,; instead the bucket keeps filling up...also can't pull the filter out for cleaning purposes... In addition are we defeat ing the purpose of the dehumidifier by placi
well if the unit has never been taken apart and cleaned well inside, and it's five years in service , Id say thats your problem, anything thats got room air blowing thru it for five years ,It's gonna need to be tottaly cleaned in all areas
Dec 23, 2014 | Danby DDR6009REE 60 Pints Energy Star...
It is three and a half years old and ices up even at warm temps.
The problem you're having is generally caused by the air intake filter needing to be removed and cleaned and/or the cooling coils need to be cleaned.
I assume you already know how to remove and clean the filter, since you've had the unit for 3 1/2 years, so I won't bore you by addressing that.
The coils can be cleaned with warm water and a mild dish washing detergent using a sponge or rag. Once they have been wiped down, rinsed and dried, apply a light coating of WD40 to the coils.
Hope this helped you & thanks for choosing FixYa.
Sep 19, 2011 | Kenmore 54701 Dehumidifier
Hi, Kenmore Dehumidifier 4254501. Brand new last
Now that you've had a chance to vent your frustration, Mike. Did you check the outlet the unit is plugged into, to make sure that it's working? Amazingly enough, I answer questions like yours all the time. And, you know what? 80% of the time, the problem is with the outlet. It's either the circuit breaker was tripped or the interior of the receptacle was damaged. And that's not counting a loose wire connection on the receptacle. So, either test the receptacle or plug the unit into another one, that's on a different circuit.
If by chance you have to replace any parts, your Kenmore Dehumidifier was manufactured for Sears, by Whirlpool. So, parts are interchangeable. And, as my son says, "If all else fails, read the Owner's Manual.
Jun 09, 2011 | Kenmore 54501 Dehumidifier
The unit runs but does not collect water...it just runs. I've left it on for several hours. In the meantime, my basement is very moist with a lot of humidity from all the rain we've had. Even my...
the units low on refrigerant or freon,its normal for these to lose their charge after 2-3 years of use,i repaired a lot of these over the years,a couple of B.P.V.'s and about 9 ozs. of whatever type of refrigerant or freon and they will go another couple of years, all for about $50.00
Jun 01, 2011 | Kenmore 54501 Dehumidifier
My 880 home dry is around 15 years old now and when on makes a loud squeaking noise, what is it and is it worth repairing , other wise works fine .regards
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
Nov 28, 2010 | Ebac HD880 Dehumidifier
My Haier HD601 dehumidifier keeps popping breaker
If you are blowing the breaker then you are pulling way to much current on the startup or you have a short in the unit...
either way you probably will be much better off by replacing the unit with a new one... they do not cost enough that it is worth sinking hundreds of dollars into fixing an old one...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 03, 2010 | Haier HD601 Dehumidifier
Why does my dehumidifer suddenly starting tripping
either the compressor is locked up or the motor start capacitor on the compressor is shorted
Apr 14, 2010 | Ebac HD880 Dehumidifier
Dehumidifier only two years old now doesn't extract water from air since I just started it up again for the summer.
Problem is that you bought a dehumidifier made by the Korean/Chinese manufacturer LG.
Search the web and you will find that you are just one of many whose dehumidifier worked the first year but now draws no water out of the air even though it makes all the right fan and compressor noises.
Most common problem is that all the Freon refrigerant escaped, apparently because the copper tubing cracked and leaked. Penguins beware, there goes the Ozone Hole!
It cost me $14 and an afternoon of investigation and testing of my LG 504EL dehumidifier to figure this out. The fix-it web site "Just Answers" said that it wasn't worth fixing after I described all the symptoms. Tomorrow I will go to the local LG fix-it shop and try to get a replacement to tide me over until I can find a reliable dehumidifier.
Sadly, last Fall I took my 25 year old Westinghouse (made in America) dehumidifier to the dump. Even though it needed me to tune it up every year or two, at least I could fix it and it kept on working for 25 years.
enterich
Jun 28, 2009 | Whirlpool AD50DSL Dehumidifier
Does Not Collect Water
sounds like a faulty humidistat, but may also be nearly out of freon. I have a GE unit that is also a portable air conditioner...works great for 5 years now...
Jul 09, 2007 | LG DH404E Dehumidifier
Kenmore 53701 Dehumidifier Logo
82 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
