Question about Singer Sewing Machines
I was given this machine and I can't get the bobbin thread to come up. I place the bobbin in the machine then snap the leave down. I put the needle down and when I raise it back up the bobbin thread doesn't come up? What am I doing wrong?
  • Singer Master
  • 7,365 Answers
try these suggestions
Check your needle to see if it's damaged
Make sure you have a 3-5 inch thread tail on both top thread & bobbin
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of machine & slowly lower needle into bobbin area & see if it will pick up the bobbin thread that way
Posted on Oct 08, 2010
How to pull the thread from the bobbin up to stick
the thread is pulled from the bobbin by the sewing action of the needle passing the bobbin hook
all you have to do is fill the bobbin , place it in the bobbin carrier , pull the thread down the slot under the flat spring and leave about 6" free
put the carrier in the machine and turn by hand several times and you will see the bobbin thread come up with the needle thead
Jun 23, 2016 | Sewing Machines
How to fill the bobbin with thread
The bobbin is a little metal wheel that is usually housed under a plate where the upper needle darts down into. Slide the plate aside and fish the bobbin out. Put the bobbin up on the upper right hand side of the sewing machine and connect thread from the full spool of thread to the bobbin and then when you push the pedal down, (if you have arranged it right), your machine will automatically fill the bobbin with thread and automatically shut off when it is full. Then you have to leave a bit of thread hanging out when you put the full bobbin back down into its hiding space. Of course, you can always fill the bobbin by hand too. When you put it back in its housing, some thread has to be hanging out as the needle will drop down, grab it and the two threads (the top one from the needle, and the bottom one from the bobbin) work together.
Machines work differently but the is the main idea behind most of them. I hope that helps.
Feb 08, 2015 | Sewing Machines
Singer sewing machine bobbin case keeps moving causing the needle to break.
Is this a front loading bobbin or top? If it is a vertical front loader with the little metal bobbin case, the metal case has to be lined up and snapped firmly into place. You should hear it snap and lock into place.
If it\'s a horizontal or top loading bobbin, and the plastic bobbin "tray" is rotating, then it may not have been nested in properly, before replacing the plate, or may be "jagged" somewhere... If there is a burr on the casing, or as in the case of one machine I worked on, still have a piece of needle stuck in it, the thread will snag on it before it finishes rotating and the rotating motion catches half way and will jerk the case right around and the next stitch will break the new needle.. Those plastic bobbin "trays" are usually easy to find and replace if they have become too burred to use. I have also sanded them smooth again as well though.
To test it, unplug the machine, thread your machine on top, but leave off your bobbin lid and leave out your bobbin, hold the top thread (like when you are about to crank to pull up a bobbin loop) and hand crank toward you, or counter-clockwise one complete rotation. Watch to see if the top thread is caught by the rotation hook and slips all the way around and back over the top of the bobbin tray, or if it snags on it somewhere.... Good luck!
Jan 15, 2014 | Singer Sewing Machines
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
May 24, 2013 | Sewing Machines
HOW DO YOU CHANGE FROM ONE COLOUR BOBBIN TO THE PREFILLED NEXT COLOUR BOBBIN
hold thread end w/3" length and put the it in the bobbin case and make sure its unwinding clockwise..Feed thread thru the higher left metal notch and pull to lower left notch and make sure the thread stays behind the spring slot and leave about 4"tail...put bobbin in its place lining up the white dots close the case and turn the wheel to drive down needle holding the needle on the machine base losely and draw the bobbin thread up
Mar 22, 2013 | As Seen On TV Sewing Genie Mechanical...
How do I thread my white 765 top and bottom
The bobbin is held in a removable bobbin case. If the bobbin case is already out of the machine, place the bobbin in the bobbin case such that the thread will come off clockwise. Leave a couple of inches of thread loose. Then pull the end of the thread down into the cross slot and thread it through the tension spring and into the delivery eye.
Next make sure the presser foot is up and the needle is in the highest position. Push the slide plate up. Hold the latch in the center of the bobbin case and place it over the center stud with the finger opposite the notch in the shuttle race. Release the latch in the center and press down on the bobbin case until you hear a click when the latch catches the groove. Leave a 2-3" length of thread extending out of the bobbin case and push the slide plate down. (Reverse the steps to remove the bobbin case.)
To thread the needle, place a spool on the spool pin with the needle bar fully up. I try to place the spool on the pin so that the little catch is out of the way. (The catch holds the end of the thread when the spool isn't in use.) Bring the thread through the guide loop on the top of the machine and then down through the thread guide on the right side of the tension discs. Bring the thread back up on the left side of the tension discs through the check spring and through the thread guide. Bring the thread through the hole (eye) in the take up lever (from right to left). Then bring the thread down through all of the guides down the face of the machine to the needle. Finally thread the needle from left to right. Pull a few inches of thread through the needle. (I find the threading of the needle to be easiest if the thread has been cut at an angle after threading the machine.)
The manual for the White 765 is available from Singer's support site. The direct link to the manual is http://www.singerco.com/uploads/download/827_white-765-x.pdf . See page 6 of the manual and the subsequent pages for pictures.
I hope this helps.
Nov 18, 2011 | White Sewing Sewing Machines
The needle will not pick up thread from the bobbin
Remove bobbin and be sure the bobbin thread is correctly placed into the machine. Put fabric, place feed dogs up, pressure lever down, hold the thread from the needle and stitch one stitch. This will have the needle go down and pull up the thread. You will never have a clump of thread under your fabric!
Jul 19, 2009 | Singer Tiny Tailor TT700
How do you thread a singer 9836c machine
I have this machine and the manual but it will be difficult to explain without the diagram. Here are the instructions without the diagram ... I'm assuming that you know some parts of the machine i.e. the foot etc
NB. thread the bobbin FIRST - points number 8 onwards....
1. Raise take-up lever to highest position on machine by turning the hand wheel towards you and make sure the presser foot is raised.
2. Place spool of thread on the spool pin at the back making sure spool cap is firmly in place to keep it on.
3. Take thread and place through the thread guide (plastic bit same side as spool pin) a under and over action. Across from this guide is a small metal wheel on top of another loop pin on the top at the front of the machine. Take the thread and put through the loop pin. 9Thread should come out on top of the pin towards you).
4. On the front of the arm is a tension wheel numbered between 0 - 8. The thread should then be placed down the front of the arm, underneath the tension wheel (behind the body part of the arm not under the wheel) and lifted up to catch the tension spring unseen behind the wheel. It should then be threaded through the eye of the metal piece (that moves as the needle goes up and down).
5. The thread should then be passed down the gap in the body work and down through the middle of the metal spiral loop in the front near the needle.
6. The thread should continue down through the horizontal clip just above the needle.
7. The needle should be place with the flat part at the back and held firmly with the screw. The eye of the needle will face you. The thread should then be threaded through the front and out the back and under the foot leaving a six inch tail.
Your thread should now come off the spool move towards the left through the plastic guide, across the top of the machine at right angles, through the metal loop; down the front of the machine (you can't see the thread as it sits behind the body) and reappears through the metal arm hole that goes up and down with the needle. It should then come down through the metal spiral and behind the clip above the needle, through the eye of the needle and away from you under the foot.
8. The bobbin needs to be wound. The bobbins are particualr to each make of machine. So only singer bobbins can be used on Singer machines. The bobbin winder is the metal pin on the right on the top of the machine.
9. To wind the bobbin. Place the bobbin over the metal pin nad push firmly down. It is located on the top on the right hand side.
10. Place thread on the spool pin as before and thread the cotton through the plastic thread guide.
11. Take the thread as before but rather than going through the metal clip on the top at the front, place it anti clockwise partly round the metal wheel on top of the metal clip (don't go all the way around) and across to the right where the bobbin has been placed.
12. The thread should be wound clockwise as many times as required not to slip off when the thread is automatically wound with the electic foot peddle.
13. Push the bobobin manually to the right along the groove in the body and press the electric foot peddle. Bobbin should wind moving the thread up and down (not necessarly evenly) and filling the bobbin. Fill about 80%. Leave a six inch tail.
14 Pull the plate forward under the needle. Place bobbin in its slot. The thread should be in a clockwise direction and when the bobbin is placed catch the thread under the groove found on the left at the top of the bobbin case. Close the plate with the thread coming out above in the slot under the needle.
15 Manually turn the hand wheel a couple of times until you can see the bobbin thread making a loop with the stitch thread and pull through.
16 Both threads should be under the foot and away from you.
17 Tension normally is around 5 -6 on the tension wheel with standard cotton and polyester cotton thread. To tighten the tension the number should increment upwards.
Machine is a cracker and according to my local shop never goes wrong. I have had mine since 1999 and that's true.
Hope this helps.... I would send you the manual but I'm not sure how you keep email addresses private.
Good luck.
Jun 29, 2009 | Singer Sewing Machines
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing Machines Logo
132 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
