Question about Micro Innovations (KB98T) (KB98TEA) Touchpad, Keyboard
I HAVE A MODEL KB7903 KEYBOARD. THE PLUG IN IS BIGGER THAN THE NORMAL SIZE PLUG IN TO MY CPU. IS THERE AN ADAPTER THAT I NEED TO USE INORDER TO PLUG THE KEYBOARD INTO MY CPU. THANKS AND WAITING YOUR REPLY
    New Friend:
  • 42 Answers
Do you mean you only have the rectangular USB plug on your computer? Some computers come with _only_ USB plugs while most will come with an additional 2 PS/2 connectors, one for mouse and one for keyboard.
Maybe you can use a PS/2 to USB plug for this keyboard to work? This solution may or may not work as I've used it for some Logitech devices but haven't tried it on alot of other devices yet.
Posted on Oct 08, 2010
  • matt nordquist Apr 17, 2011
    yes they do and they are fairly cheap. i know the keyboard you are refering to. a larger plug were from older systems but once adapted to fit a smaller port, will be just fine with the latest out there.
I have a ac adapter model JTHY-912 input:110-240VAC 50/60Hz max0.3A OUTPUT:5V-2000A. It does not work and am unable to find one in store. Where can I find one?
Just match the VOLTAGE OUTPUT of what the equipt requires...and...meet or "exceed" (bigger amps does not matter of the adapter "transformer") Not that this answeres "where you can get one?) but if you come across one, keep that in mind. By the way,...What the h*** requires 2000 Amps!!!! Surely you meant "miliamps"? ( or mA)...Check it again. ( mili is 1 one thousanths)...so...2000 miliamps is 2 AMPS by the way) If so you can find a million of those! Just cut the origonal plug off and wire on to your new one. (( make sure polarity + & - are correct and not reversed. You will need a meter to check. ((( Your old adapter will have a picture on it of what the center of the plugs polarity is etc))) ...You still will need a cheap meter as the wires are not color coded...Just match it. Remember: Exceeding the amp rating of the new adapter is good. ( adapter BIGGER / MORE than the devise.
Sep 24, 2017 | Computers & Internet
What motherboard is in asus k50i-rbbgr05 and whats the best cpu upgrade for it if any currently Pentium duo core t4400
Hello here is the asus home page:
http://www.asus.com/Notebooks_Ultrabooks/K50IJ/#support_Download
Try to contact the asus support before upgrading the cpu.
Your laptop will probably not support a bigger cpu, because there is a limit here.
The cpu from another model will probably fit the socket, but the pc will not boot at all.
This depends on how the mainboard is build, cache size and so on.
Its also very expensive to buy a cpu for a laptop.
This can easy cost the same as a new laptop.
The mainboard is build by asus or intel.
It would be easyer to by a laptop with a bigger cpu.
They do exist as quad core.
Good luck
Jun 12, 2013 | Computers & Internet
My tower is plugged in and the monitor is plugged in but my windows will not show up on my monitor. It says to hit a key to get out of power save but wont do anything
1. Swiched CPU power off (But Monitor on - though blank )
2. Removed motherboard battery(its like a watch battery but quite bigger)
3. Then Swiched th CPU on
4. On screen message ( the I pressed F1 on the keyboard) .
now see what happen.
Aug 15, 2012 | HP Computers & Internet
Call of duty black ops will not save the game in my console
You will need one of two things inorder for your game to save. 20 (or bigger) HDD *harddrive* or 64MB memory xbox360 game card. If you already have a memory card or HDD please empty some of the information saved to install remaining memory. Memory size can be anywhere from 1.5Mb to 16Mb.
Mar 17, 2011 | Microsoft Xbox 360 Console
We have a desktop computer((Model: GATEWAY 838GM) misplace the ADAPTER for the CPU which one to get please thanks
sallyduby we may have some confusion here.
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
CPU does not refer to a Personal Computer. At least not since the 1960's, and not unless you wish to confuse someone with the wrong reference. ;)
This is Gateway Support > Gateway 838GM Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/5389/5389nv.shtml
In the list click on Components.
A) There is no adapter device for the CD drive, or DVD drive, unless this is a mistaken reference to the flat ribbon data cable
B) There is no adapter device for the Harddrive, unless this is a mistaken reference to the SATA data cable that connects the SATA harddrive to the motherboard.
C) There IS possibly an adapter for the Keyboard, if you are using a Keyboard with a USB connector on the end of the cable, and are not using the original Keyboard that has a PS/2 connector.
Example;
http://www.directron.com/freeusbps2.html
D) There is no adapter for the Media Card Reader, unless this is a mistaken reference to the data cable that connects the Media Card Reader to the motherboard.
E) There are no adapters for the Ram Memory module/s.
F) There are no adapters for the Modem. The Modem plugs straight into the motherboard.
G) There are no adapters for the Motherboard, unless a USB mouse, or again a USB keyboard, is being used.
The same style of adapter for the USB Keyboard will also work for a USB mouse.
H) There is no adapter for the Power Supply, unless this is a reference to a power cable adapter that could go to a computer case fan, from a 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The 4-pin standard Peripheral power cable, and it's connector, are shown in the middle photo.
The Harddrive example/s shown is an IDE {PATA} harddrive. This style of Harddrive uses a 4-pin standard Peripheral power cable)
I) There is no adapter for the Intel Pentium 4 CPU {Processor} (3.0GHz, 800MHz FSB)
The motherboard has an LGA 775 processor socket.
The Processor has the socket holes, while the processor socket has the pins.
775 socket holes, 775 pins.
http://en.wikipedia.org/wiki/LGA_775
Unless this is a mistaken reference to the Fan/Heatsink combo that sits on top of the CPU.
Typical Fan/Heatsink combo example of Processors (CPU's) using an LGA 775 processor socket,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2943299&CatId=493
(Except the Gateway version is square)
J) No adapter for the Speakers unless I am mistaken.
Post back in a Comment, and give at least a general description of the adapter you are referencing to.
Regards,
joecoolvette
Dec 12, 2010 | Gateway 838GM (RB838GM) PC Desktop
My dos windwo is small, how to get its size big
hello this is breen from ramanathapuram... inorder to solve ur pblm... i.ve a solution..... just type ALT+ENTER key to make ur dos window size bigger.... byeee
Jul 11, 2009 | Acer AL1512BM 15" LCD Monitor
Replacing the fan or fans in a dell 4600 with the quietest fan I
First you need to tell us which fans are the loud ones you are talking about but normally it is the cpu fan. Any computer parts store should have various fans available for different chipsets.
This link will take you to a page to find a fan. You will probably have to get the model number off your current one to find an exact match
http://www.frozencpu.com/cat/l3/g36/c15/s700/list/p1/Fans-12_Volt_Fans-92mm_x_38mm_Fans-Page1.html
Jan 07, 2009 | Dell Dimension 4600 PC Desktop
Sony memory stick pro duo is too small to fit in my computer media stick compartment. it won't read
its to small b/c when u bought the media stick it should have came with an adapter that you put the stick into and it makes it bigger inorder to fit into the computer.
Sep 17, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Cooling fan
depends on what the socket cpu your running is you can go bigger with the a bigger heat sink
May 20, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Micro Innovations (KB98T) (KB98TEA) Touchpad, Keyboard Logo
258 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
