I need an operating manual for our key card machine and door locks for our Vingcard machine. It's a VC2100 2S System with corresponding locks. Our phone # here is 269/ 469-4440 or 888/ 627-4364
  • 14036 Answers
SOURCE: 1999 oldsmobile Alero Door Lock
sound like the bi directional solenoid. your power window has two of them . unlock solenoid lock solenoid .sound like the lock solenoid is bad or the relay or it could be a short.
Posted on Mar 19, 2009
  • 83 Answers
SOURCE: 2001 saab 9-5 electric door lock system does not function
Most likely you have a bad TWICE unit. it is located under the driver's seat, at a low point in the floor and often gets wet.
Posted on Mar 25, 2009
SOURCE: operations manual for Panasonic Phone System part # kx-tg5634
Problem has been solved. I was able to locate a Panasonic manual for our quad phone. Sorry to have troubled you.
Thank you.
Posted on Jun 24, 2009
  • 59 Answers
SOURCE: can't open locked trunk. used key, turn to left
A good locksmith can get this open for you. we used to do these all the time...due to age we don't see many any more. Either the linkage has come off the latch or the vacumm system to the latch is not working.
Posted on Aug 27, 2009
  • 239 Answers
SOURCE: Hi My 328i Coupe central locking system has got
You have a burnt solenoid for lock on the drivers door.
Posted on Aug 31, 2009
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Daytime running lights (DRL)
Automatic lighting control
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
Dec 12, 2015 | Renault Megane Cars & Trucks
Need to reassemble at vingcard 2100 lockset
I can help you out. Please contact me from the "contact us" page on my website www.ElectronicLockSmith.com. I need to get a little more info from you about the version and then I can provide with you some help. You can also call me Monday-Friday. Thanks, Ken Croston Jr. 407 814 8974
Nov 22, 2012 | Locks & Locksmithing
12/6/2010 2003 bmw 325xi: Key does not manually lock/unlock driver door...but still works in ignition and trunk...central locking system still works to lock/unlock all doors(including driver) from...
If the key turns in the lock, but does nothing, then the linkage has become disconnected or broken. The key is mechanical to the lock and the lock has a electrical switch to operate the central locking unit. Could be a simple broken clip from the lock barrel. Hope this helps
Feb 27, 2017 | 2003 BMW 325
After battery replacement keyless entry stop working
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative. Key batteries replaced.
How - early models
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should operate normally after approximately 1 minute. If not, carry out programming procedure.
How - late models
If vehicle locked, manually unlock driver's door using key. Press key unlock button once. Switch ignition ON and OFF. Remove key from ignition switch. Press key lock or unlock button once. System should now operate correctly.
Jun 24, 2010 | 2007 Audi A4 Convertible
2003 audi a4 had dead battery, charged battery and now the key fob won't work and the security lights flash for about 5 min everytime I do anything to the car. why ?
Synchronization
When
How - early models
How - late models
Apr 12, 2010 | 2003 Audi A4 Cabriolet
2005 Chevrolet Silverado Automatic door locks
I assume you mean that the central locking system will not lock the doors but you can do so manually.
Get inside the vehicle and close all doors.
On each rear door, lock and unlock the mechanism manually a couple of times. In other words do not use the key pad.
Then leave both rear doors in the locked position (manual locking) and operate the lock button on you key pad to operate the central locking system. Wait a few seconds then hit unlock on your key pad and a few seconds later hit lock on your key pad.
If the system fails to lock your rear doors you will need to get the vehicle to an auto electrician to check out the issue and rectify it for you. There are a number of possible causes which cannot be identified without physically checking the system. So you will need to have this rectified by a professional.
Dec 04, 2009 | 2005 Chevrolet Silverado
Rear doors unlock but will not lock
Automatic door locks will not lock rear doors, they open fine when manually locked but will not lock with switch key fob or when put in gear.
You mean that the central locking system will not lock the rear doors but you can do so manually.
Dec 01, 2009 | 2005 Chevrolet Silverado
336 people viewed this question
k24674
