Question about Nokia N95 Cellular Phone
Up,Left,C,Media,1 & 8 keys not working on Nokia N95 8GB
I have a bit problem that started in like a second after i was just using the phone. The above mentioned keys stopped working. I have tried reinstalling the firmware to checking if water was dropped on the phone but i dont seem to get how this is happening. Could you help please? Email back on paul_jigolo@hotmail.com
  • davewri Jun 06, 2008
    Got the same problem as you, up, left, c, media, 1 & 8 keys are not working, do not know what to do.
Having the same problem, Phone was 2 weeks old then this.
Sent my phone to the nokia repair center and have been waiting for 4 months now... still no phone
Anyone found out what the problem is?
Posted on Jun 09, 2008
How to unlock keypad nokia 3110c.
It sounds like your keypad lock (keyguard) is on.
To unlock the keypad, press Unlock and then press the asterisk key (*) within 1 and a half seconds.
The word Unlock appears above either the "Left Selection Key", the "Middle Selection Key" (4-way scroll key), or the " Right Selection Key" just below the display, indicating which key is currently the "Unlock Key".
May 23, 2011 | Nokia 3110 Cellular Phone
Tip
.:: Speed Up Your Nokia S60 Phone ::.
The method:
1.Set your log duration to 1 day or No log if possible. Works wonders! Normally, the call log list defaults to 30 days, but that's completely unnecessary, at least from our speed point of view.
Open up the Log application, hit options (left softkey), and select the Settings option. Change the Log duration to (optimally) 1 day or No log if possible. Either way, it should give you a noticeable speed increase.
2.Delete install log.. See my Screeshots..
3.Delete media log... Follow Screenshots..
4.Finally, keep your phone's firmware updated! All right, that was a cheap one. But seriously, sometimes Nokia actually improves the user interface a bit - take the latest N95 firmware, for example, which speeds up the Gallery by removing the mean bug that caused the gallery menu to appear for a second or two before (slowly) sliding off the screen.
on Aug 31, 2009 | Nokia 9500 Communicator
My nokia n97 fails to start and its diplay contact retailer plzzz help me out
Note: You may back up all your information on your phone before doing a hard reset
Steps to hard reset your Nokia N97:-
1. Switch off your phone.
2. Press left shift key (first key in the third row), the space bar key and the arrow key (last key in top row) simultaneously.
3. Keeping the above keys pressed, press the power key. Keep all four keys pressed till your phone asks for country details etc.
4. Now you may release the keys, fill in the details and you are done.
Apr 26, 2011 | Nokia N97 Cell Phone
I put a lock code on my phone and forgot the numer
use code
*#7328748263373738# to reset security code to default.
Default security code is 12345
for expert choise
hard reset your phone:
1. Switch-off the phone (Remove the battery and re-insert it, if necessary). Now Press and HOLD the GREEN (Call) key, RED (Call end) key and the Camera-capture key SIMULTANEOUSLY. While still pressing the above three keys press the power On/Off key, hold them until phone boots up.
2. Nokia N97 and N97 mini - Press and HOLD the left shift key, spacebar key and the back key simultaneously. While still holding the above three keys, press power-on key, hold them until the phone boots-up.
NOTE however that the format will erase all the data in phone memory and you will also lose your free music that came with the phone. Also make sure to fully charge the phone's battery before the format process.
Mar 12, 2011 | Nokia 5800 XpressMusic Smartphone
Hi. i have Nokia N97 When i Turn On the Bluetooth it shows a massage by the name of Unable to perform Bluetooth operation how i can solve this Problem please solve my Problem and Send Me all information...
Mar 12, 2011 | Nokia N97 Cell Phone
Sir, My Nokia 5200 phone's down key right key does not work sometimes, exept them all keys are working properly, plz sir give me a valuable solution that I can easily overcome from the said problem.
Most models slide to open this common problem. The main thing I suggest you change the new ribbon cable. is not about just the keypad will not work if the ribbon cable is damaged, but lcd display is not functioning properly if the ribbon cable is damaged. You are lucky to still be able to use it even can not move left or right, if not berfunggsi menu button, you can only power on mobile but can not use it.
Jul 27, 2010 | Nokia 5200 Cellular Phone
How do i padlock my phone
Do you mean Key Pad Lock? if it is so then follow .... Return to the Screen mode by pressing the RED button on the Right Side - Press the Green button on the Left side just above 1 and again press star * but you should do it within 5-10 seconds .. marvinii22.jpg?w=360&h=480 Good Luck
Apr 30, 2010 | Nokia 6600
Gud evening sir im ravi my mobil model no is nokia 3110 c i have one problam my musiplayer is not opening how will solve that prolam
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.1. In SETTINGS/DISPLAY/ACTIVE STANDBY/ACTIVE STANDBY MODE (TURN ON)/PERSONALIZE VIEW (MAKE IT THAT SHORTCUT BAR IS THE ONLY ONE THERE)
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key, options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down, central button, left blue line, down, central, up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line, center, left blue line, down, center, center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
Dec 04, 2008 | Nokia 3110 Cellular Phone
Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
Nov 30, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
