Question about Sharp AL 1631 Copier
When I try to make a copy the machine make a screeching noise and a blank copy comes out.
  • 1,110 Answers
Leave the lid up when you make the copy and see if the light bar moves from left to right when copying. Check the scanner lock knob under the left hand side where the papers come out. Make sure it is not locked. Sometimes the scanners get stuck a lot and can cause blank copies. If it is stuck then you just have to remove the glass and then clean and lubricate the steel bar at the back that the whole unit rides back and forth on. Once that is doene it should work fine. Make sure to manually run the scanner bar out and back a few times so that you can get the whole rail lubricated. Do all this with the power turned off.
Good Luck and Thank You for using Fixya.
If I helped, please let me know via a testimonial today!
Posted on Oct 08, 2010
Everytime i try to copy or print anything theres a really loud screeching noise coming from the inside of it... how can i fix it?
Please call your local servicer for better problem diagnosis. It might be an issue with the printer's printing mechanism.
Dec 03, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Screeching while scanning
it may be want to lubricate the scanner rode
Mar 23, 2010 | HP Photosmart 3210xi InkJet Printer
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Copier was working and copies were fading so we
Make sure you remove the seal tape on the new cartridge thats why it making noise then install properly.
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Canon IR1600 Loud Screeching Noise During Copying
There are some little metal earth strips that meet the paper exit shaft at the fromt of the machine. I've had a couple of these digging intot he metal exit roller shaft, they just needed bending away from the shaft anbit and oiling. It also helps if you move the exit roller shaft from front to back a bit.
Mar 12, 2009 | Canon imageRUNNER C3170U Color Copier
GE topload washer occasional screeching noise during wash cycle
It sounds like it could be a brake pad that has broken and is partially rubbing against the brake frame.
Mar 07, 2009 | GE WJRR4170E Top Load Washer
Loud, screeching noise when taking a message
Managed to clear it myself. After making several cell phone calls to my machine last night and unplugging it over and over, etc. I gave up. This morning I again unplugged everything, reset all the settings and called the machine several times. At first I kept getting the "noise", but eventually I was able to call and leave a normal sounding message. Can't really explain what "cured" it! In desparation I did shake the machine and give it a hard slap, but who knows what did it!
Apr 05, 2008 | GE 29875GE Digital Answering Machine
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
MAyatg MAV7600 BGN Top Load Washer Problem
The screeching sound could be the drain pump or something stuck between the bowls. Try turning the inner bowl by hand and listen for the noise. There should be a position on the timer, just before the spin, that allows the machine to drain before it starts to spin. Try to find the right spot and listen for the noise when only the drain pump is running. Good Luck.
Oct 31, 2007 | Maytag MAV7600 Top Load Washer
Sharp AL 1631 Copier Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
