Question about AT&T Spirit 6-Button Stard Misty Phone
I have an AT&T Spirit phone system. I"ve moved and taken the system with me. The phone now calls out on a pulse mode. Automated answering systems that I call will answer but will not respond when numbers are asked for to route my call to various departments. It acts as if I"ve pressed no button at all. It seems that my Spirit system has switched from touch tone mode to pulse mode. I've tried to reprogram back to touch tone mode but the system does not respond to these attempts. I suspect that my problem is that I do not know where the control unit administration switch is located. I believe that if I find that then my attempts at reprogramming the system will work. Can you help me?
  • drkrossmd Oct 08, 2010
    My system is the Spirit 1224. Not 303.
    I know how to disconnect the AC adapter from the AC power. I do not know where the battery for the handset would be. Is the solution for the 1224 system different from the 303606 system?
    My AT
  • AT&T Master
  • 2,460 Answers
If you have a standard 308/616 tan cabinet, look at the green POWER light. Ooh, right next to it is a switch labeled ADMIN and it says ON OFF :-)
There's your admin switch.
Carl
Posted on Oct 08, 2010
    Genius:
  • 1,478 Answers
Have you try to reset it? If no, Just try to reset it to factory settings.
Remove the AC Adapter from the AC power (either at the base or at the wall outlet) and immediately connect it again. Remove battery from the handset and immediately replace it. Place the handset back into the charger for about 5 seconds. That should reset the phone and put the phone on default.
Take care.
When I call a number and they want you to press certain number on your phone,well on my phone I can't press any number except to dial a number.
Check and see if your phone is set to tone or pulse? If it is on pulse you need to change it to tone. If it is on tone, check and see if you have a send button, you may have to press it after you press the number...
Jun 27, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I connect a directv remote to panasonic SA-HT680?
this is what I did & it took all of about 5 minutes.
call tech support for direct TV & they will walk you through the process.
the phone # should be on your bill or you can Google it.
when you call the #, you will get the automated system, say I want to talk to a representative, (tip - if you sound upset to the automated system it will put you through sooner & won't run you in circles for so long, the system is designed to read your responses.)
Nov 26, 2014 | Directv RC65 Remote Control
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
AVAYA PARTNER ACS PHONE SYSTEM
Yes it can. Depending on the type of voice mail attached to your system you can both have the lines answered with a seperate main greeting (partner messaging can do this) or answered by a seperate mailbox (all partner voice mails).
Oct 06, 2009 | Lands Phones
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Time consuming incoming automated phone call
With a CallPilot voicemail system, you could have the system recognize the caller id info of the call and send it directly into a mailbox, eliminating the need for your digital answering machine. That's the only option I am aware of.
Hope this helps.
Mar 28, 2009 | GE 29869GE2 Digital Answering Machine
Making a phone call to an automated system
Call the automated system and press # key before dialing further keys.
Feb 02, 2009 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
AT&T Spirit Phone
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Aug 05, 2008 | AT&T Spirit 6-Button Stard Misty Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Open Questions:
See all AT&T Spirit 6-Button Stard Misty Phone Questions
AT&T Spirit 6-Button Stard Misty Phone Logo
174 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
