Dear sir, still if the same,then plz change your battery( for eg:lithium ion battery or the battery prescribed for the model,plz note:before changing battery make sure you buy the battery specified for your cam), if still the problem persists,then the problem usually caused by virus which happens when you are receiving files from p.c or untrusted devices...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest panasonic service centre.. thank you....take care thank you...take care
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
