Question about Hitachi ED-X3400 Multimedia Projector
How do I reset the lamp timer on the Hitachi Projector ed-x3400
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
Marrie
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
Marrie
  • 563 Answers
SOURCE: Hello Wardens wife
Hi Airbala
This Projector does have a filter timer.
Go to the Options Menu and select Filter Time - then reset it.
  • 105 Answers
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
  • 3 Answers
SOURCE: Reset Lamp Hours Timer
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "VOLUM -" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
This works for Toshiba TDP T-9
Posted on Jul 11, 2008
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Re set timer?
    hi,
    To reset the lamp hour timer do the following,
    1. Power on the projector
    2. press the menu button
    3. Select option
    4. in the option menu select Lamp time
    5 press and hold the reset button on the remote or Right arrow button on the projector for 3 seconds
    the lamp reset diagonal box will appear
    6 using the up arrow button select reset.
    Also try to reset the filter time using the same procedure
    lamp reset is recommended only after the lamp replacement.
    ok
    Apr 04, 2011 | Hitachi CP-RS55 LCD Projector
    Getting message "After replacing lamp, reset the lamp timer." How do I do that?
    From the manual located here.
    Turn on the projector, and reset the lamp timer.
    (1) While the projector running, press the MENU button to open the menu.
    (2) Choose the “OPTION” on the menu using the up/down arrow button, then press the right arrow button or ENTER button.
    (3) Choose the “LAMP TIME” using the up/down arrow button, then press and hold the
    RESET button for 3 seconds.
    (4) Choose the “RESET” using the up button.
    May 18, 2010 | Hitachi CP-X1250 Multimedia Projector
    Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
    try looking for your thermistor usually located near the wind path its a small block the size of two match heads usually mounted off the main board with two wires this is your 'heat switch' so to say, also check your fans are clean and running there is normally more than one.
    May 15, 2010 | Hitachi ED-X8250 Multimedia Projector
    reset the lamp and filter timers. turn the projector off then back on.
    Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
    Can't reset lamp timer
    (2) Choose the “OPTION” on the menu using the / button, then press the
    (3) Choose the “LAMP TIME” using the / button, then press and hold the
    (4) Choose the “RESET” using the button.
    memo When the lamp has been replaced after
    Dec 11, 2008 | Hitachi CP-X1200 Multimedia Projector
    If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
    Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
    Reset lamp timer
    found a solution... hold the reset and left arrow untill message appears on bottom of the screen then release then use arrow button to return timer to 0
    Apr 12, 2008 | Hitachi CP-S860 Multimedia Projector
    Hi there
    Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
    Hitachi CP-X250 LCD Projector
    clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
    Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
    Hitachi ED-X3400 Multimedia Projector Logo
    313 people viewed this question
    Top Hitachi Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
