Question about Texas Instruments TI-83 Plus Calculator
My ti-83 stopped working after i used rechargeable battteries. Now i realized I'm not suppose to use them. Now whenever i turn the calculator on, i can't turn it off. I will try to press letters or numbers but nothing works. I can't turn it off either. HELP
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
I'm thinking the calculator itself froze (stalled), or the circuit board is taking a long time to process the your command (telling the calculator to turn off). Maybe you should wait a few hours or so and see if it's still on. Did you perhaps take the batteries out while the calculator was still on? You may have damage the circuits inside of the calculator by taking the batteries out while the calculator itself was still on. Maybe if you put some new batteries in the battery compartment and press the "ON" button, it might function properly. This is a suggestion and I hope this works.
Posted on Oct 08, 2010
  • hoangyenpham Oct 13, 2010
    No I didn't take out the batteries when it was still on. I tried using new batteries, nothing works. Nothing works in general. I can turn it on, like the black square that usual appears beeping when you turn it on. I tried pressing buttons and etc, nothing appears. I can't turn it off either.
  • Rielle Burst Oct 17, 2010
    These are some more suggestions that might help. I saw two solutions in the guidebook. You can download calculator system software. Remove one battery from the calculator and then press and hold the "DEL" button while re-installing the battery you removed. Doing this will force the calculator to accept a download of system software. Connect your calculator to your PC with the TI-GRAPH LINK (I think it's the cable that came with your calculator). This will download current or new software code to your calculator. Just plugging that cable into the calculator without plugging in the other end of the cable will turn it on. Try pressing buttons on your calculator to see if they function properly.
    If that doesn't work, try resetting the memory by removing one battery, then pressing and holding the "CLEAR" button while re-installing the removed battery. While continuing to hold down the "CLEAR" button, press and hold down the "ON" button. When the home screen is presented, release the buttons. Press "2nd [MEM]" to display the RAM ARCHIVE ALL menu. Press the right arrow buttons twice and select "1:All Memory" to display the "RESET MEMORY" menu. Select "2:Reset". The message "MEM cleared" is displayed on the home screen.
    If that still doesn't solve the problem, I would consider three things... Either going to this support website-http://education.ti.com/support and contacting an associate, or unscrewing the calculator and taking out the buttons and observing the copper tracks (the object that is on the circut board under the buttons). Try fiddling with them by pressing them (batteries should be inserted in the battery compartment) to see if they work. Maybe the computer CPU inside of it wasn't receiving the information being punched in via the buttons. I've never looked inside the calculator for this model, but in one of my dictionaries I have a picture of a calculator and some of its internal parts. Your calculator may have a circular-shape lithium battery that is called the button battery. If your calculator has one, then that is probably what your problem is, so you will need to replace this battery. If all of that doesn't help, then you will have to go to plan B, which is to replace the calculator by purchasing another one. Hope all of this solves your problem and hopefully you won't have to buy another calculator!
Ti 83 plus charger
The TI 83 is a calculator, not a battery charger. If you want to use rechargeable batteries with it, you have to take the batteries out and charge them using a separate battery charger.
Jan 23, 2013 | HP 12c Calculator
What kind of battery does the TI-83 take
4 AAA batteries and one CR1616 or CR1620 button batter for backup
Source: http://en.wikipedia.org/wiki/TI-83_series
Sep 15, 2011 | Texas Instruments TI-83 Plus Calculator
My ti-84 calculator wont react to anything and it says garbage collecting. i think the bar on the side should move and its not moving and its been like this for several weeks. i did download a whole pile...
I remember this happening once to my TI-83. I know it's a different calculator. But it happened frequently. Without completely reconfiguring the calculator, you can remove the batteries whenever you see the message and when you start it up again, it should be okay. It may continue to display this message once in a while. I used to just remove the batteries. I don't know if it will work on your TI-84 the way it worked on my TI-83, but I hope this helped!
Please rate my solution!
- Frankie
May 05, 2011 | Texas Instruments TI-84 Plus Calculator
The TI 83 Plus was purchased in Sep 09 for my high school freshman. It hasn't been used much and now will not turn on. I've replaced the batteries twice. Any suggestions? Can it be repaired? Thanks
If the batteries are rechargable they may need to be removed and recharged. Lack of use does not mean that they hold the charge forever.
I don't know but try it.
Pete
Feb 11, 2011 | Texas Instruments TI-83 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
Whenever i try the graph on my TI-83 Plus the ERR:INVALID DIM 1:QUIT comes up and ive checked the STAT PLOT and i have Plot 1 set as ON.
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
Sep 09, 2010 | Texas Instruments TI-83 Plus Calculator
I'm an older student.....in my 50's. I am taking classes to complete my bachelor's degree in nursing, something I should have done 30 years ago. Better late than never, right? Anyway, I found my son's TI...
Hi Anne,
here are some tips to use your TI 83 calculator. Patiently follows this:
  1. Press ENTER to find out the answer to an expression.
  2. Press 2ND before pressing a button to use the function in yellow above the button.
  3. Press ALPHA to enter in letters.
  4. Press 2ND before pressing Alpha to turn on Alpha lock, which will automatically use the alpha mode until you press a directional key or ALPHA again.
  5. Press 2ND and then hold up or down to adjust the screen contrast accordingly.
Advanced Instructions
  1. Press MODE to go to a menu that allows to change graphing modes, degree modes, and notation modes among other things.
  2. Enter in a number then press STO> then enter in a letter and hit enter to store values in variables.
  3. Press Y= and enter in a function and then press GRAPH to view it. If you are having trouble viewing it, press WINDOW and adjust the graph's window.
Thanks,
Cherile
Aug 30, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 is all messed up
Sorry to hear that you are having problems with your TI-83. The TI-83 is a discontinued calculator, so I really don't think that it can be repaired/replaced.
See TI's website below for more information:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71440&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGEE602C53EA628B70E47DD2DD6878A5ABD632AD5834DE8ADC18D66ABBC9F888CBF7FB517A0B05B0984776B37370A28975B2
Feb 24, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
195 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
