Question about Brother LS-1520 Mechanical Sewing Machine
Difficulty threading bobbin- thread bunches under fabric. vx1005
  • Brother Master
  • 7,365 Answers
I would suggest to check the needle to see if it's damaged
also check to make sure the machine is threaded correctly,,that the thread is in every thread guide
also some sewing machine have a problem with the top thread coming off the thread take up lever
also I would check the bobbin area for lint or any loose threads
also check the top thread tension to see if it's set correctly
also the hook race cover & hook need to be taken out & cleaned & then put back in
some machine have had problems with the hook getting grooves worn into them & need to be fixed or replaced
Posted on Oct 08, 2010
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
I checked my thread and bobbin watch the video and my machine keep bunches the bottom stitch
Is it really the bobbin thread that is bunching? Generally, thread messes under the fabric are the fault of the top thread, and thread messes on top of the fabric are a bobbin problem.
Top thread bunching under the fabric is called "thread nesting" or "bird nesting" but I prefer to call it thread "barfs." Most often, it occurs because the top thread has not been seated completely in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
RAISE the presser foot and rethread the top thread.
(Verify the thread path is correct.)
Set the top tension disk at the midway point.
Retest your machine. Tweak the top tension if required.
Mar 27, 2017 | Sewing Machines
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
Bobbin issues the bobbin thread is bunching up
Check whether it is bobbin thread or the top thread accumulating under the fabric. Generally, if thread problems exist "under" the fabric, it is a top thread issue. If the problems exist "above" the fabric, it is a bobbin issue.
Sounds like a thread nesting (bird nesting) problem where the top thread is globbing under the fabric. Usually, this is caused by misthreading (confirm the thread path), the thread not seated in the tension disk (ALWAYS RAISE the presser foot when threading!), or very loose top thread tension.
Remove the thread. Raise the presser foot and rethread from the beginning. Check that the thread path is correct. Set the upper tension at the midway point between high & low numbers (this is the beginning point for tension and will most likely need to be tweaked for your particular machine).
Sewing Machine Thread Bunching Up Here Why
Dec 11, 2016 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
Feb 06, 2016 | Consew Sewing Machines
Thread bunching underneath fabric on Bicor VX1005 mahine.
The impulse is to blame the bobbin, because that's where the thread bunches. But the problem is probably with the top thread tension. The tension is too loose, allowing the bobbin to help itself to all the thread it wants. Retrace the path of the thread from spool to needle and see if you missed anything. The instructions in my VX1005 manual are not clear. I had to try a couple of paths before I got it right. Make sure the spring in the tension disk setup is moving freely. You should feel a fair amount of resistance when you pull on the needle thread. Hope this helps.
Terry
Nov 11, 2008 | Bernina Activa 130
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Brother LS-1520 Mechanical Sewing Machine Logo
173 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
