Question about Dell E153FP 15" LCD Monitor
I have a dell 153fp and it is brighter at the bottom of the screen than the top. It also makes a very high pitch noise. Is there any fixes for these issues?
  • Louis Ebert Oct 08, 2010
    pctierno, It's old!! In terms of monitor age, Very old! Retrevo . com will list this unit as "time to retire." If you are "hell-bent" on "refurbishing" this unit, then go and watch some video clips at YOUTUBE to see just what you are letting yourself into!!! I'm certain you wiil find a Dell 172fp or 173fp video to watch there. May need cheap soldering pencil (25w to 40w), some solder wick, solder, wire cutters, new capacitors for power supply board, and source for new CCFL fluorescent lamps. Do a reply and let us know your decision after you do your RESEARCH!!!
    12fixlouie
  • 11,361 Answers
Check the lamp caonnector (white connector with pink and white wires ,or pink and black wires), look for arcing on the board around the inverter transformers. It sounds like the top lamps are not on fully. It can also be from bad soldering works at the lamps ends.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Please post back what you find.
Posted on Oct 08, 2010
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Feb 17, 2012 | Sony Audio Players & Recorders
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
Fan in top of the refrigerator is making a high pitched whine when running
The high pitched noise is likely a bearing on the fan motor going out. You should replace the motor soon as it may fail completely.
Oct 18, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
Dell E153FP 15" LCD Monitor Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
