Question about Lexmark P6250 All-In-One InkJet Photo Printer
Require ac/dc power supply where can I purchase one?
    Genius:
  • 1,087 Answers
You should contact Lexmark technical support for assistance with the power adapter. Thanks.
Posted on Oct 08, 2010
Does Huawei S6720 Switch has 600W DC power supply?
In fact, Huawei S6720 Switch has with 600W AC power supply, 350W DC power supply.
qq??20170907163228-2unbjz2gdcyqx1b141tbj330-2-0.png You can check in http://itprice.com/
Jun 28, 2017 | Huawei Computers & Internet
What type of power connection do I need for this plug
Norm it is not a simple matter of getting a power connection you will need the correct power supply for your recliner .
This might be the power supply unit you will require
however you need to check if the recliner uses 29 volts DC it may be marked on the recliner . You may need to get someone to help you look closely at your recliner to see if there is a label with its operating power voltage and if it is DC or AC and current ..
https://couchguard.com.au/lift-chair/electric/electric/power-supply.php
May 31, 2016 | Computers & Internet
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
My dc691p speakers require 9 vold dc. Will it do any harm to use a 19 volt dc
yes, your speakers will be damaged. do not connect 19 volts to a 9 volt device. go to walmart or radioshack and purchase the correct power supply.
Mar 01, 2014 | Juster AC-691 Computer Speakers
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
Please tell me about power supply problem and solving diegrame
The power supply for HDTV is the board where the AC plug goes into. It is a very sensitive circuitry that can be easily damaged. Under normal circumstance it is very reliable. This is how they work basically. The AC current is rectified (converted into DC). Then filtered by means of large capacitors. The DC Voltage ( about 180 DC volts from 120 AC) is supplied to power transistors (usually FET or field effect transistor). The Transistor are switched at high frequency( usually over 100KHZ or 100,000 times per second) Which drives the transformers to step down the voltage. When the TV is off there is a standby voltage which is on at all times, and it is typically 5V. This standby voltage is the first thing a technician check for when troubleshooting power supply problem. When the TV is turned on everything in the power supply comes to life supplying power to every circuit boards which are of diffrent voltages such 12V, 24V etc. HDTV power supplies are very complicated using the latest technology employing power saving chips that minimize power usage on standby mode. Explaining the it in great detail would require many pages but this is just the basic.
Jun 26, 2010 | Sampo PME-42V3 42 in. Plasma Television
I have a 2811 router with a PWR-2811-DC power supply in it. I have a PWR-2811-AC power supply that I would like to install in place of the DC input supply, but there is a second internal electrical...
No.
AC power is like a child's swing -- it goes from "neutral" to "positive" to "neutral" to "negative" to "neutral", and repeats.
DC power is like leaning into a strong wind -- as long as you keep leaning, you stay on your feet; stop leaning, and the force of the wind will blow you down.
So, you cannot substitute AC for DC power.
Mar 03, 2010 | Cisco 2811 Router
I have a thermoelectric wine cooler (heintzman DC2-40C) that no longer cools as it should....help....
Thermoelectric devices (or modules) require direct current (DC) for operation. Alternating current (AC), the form of electricity found in wall outlets, causes a thermoelectric device to alternate between heating and cooling, rendering it effectively useless. "Ripple" is the AC component of DC current and occurs when a power supply does not completely convert AC current to DC current.
You just might want to find out why the AC is not turning to the DC required, This could be a matter of chaning outlet plug or maybe the Ower pack that coverts the AC to DC.
Jan 01, 2010 | Refrigerators
3M Projection Panel. Model Number 4180
input ac 120V 60HZ 40 W
output DC 12V 1.5A
as to any other functions I have no idea
May 06, 2007 | 3M Projection Panel 6400 Multimedia...
Lexmark P6250 All-In-One InkJet Photo Printer Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
