Question about HP LaserJet 4si Printer
How to cancel job in buffer
I have an HP Laserjet 4si. I have a large job that doesn't need to print (1000 pages). It is already out of the print queue in the software (PAC). It is now in the buffer. No matter what I do to kill it, it keeps coming back. I have turned it off, unplugged it, do a cold boot, a reset, change something in set up and did a cold boot to accept the change. Also, the font and orientation is all messed up. HELP! I do not have a "cance" button on the panel.
  • MonicaTess May 30, 2008
    It worked! I had tried everything...I thought. I did pull the power cord, but didn't wait very long before plugging it in. I never thought about the printer cable....thanks a bunch!!!
  • Anonymous Nov 19, 2008
    can't cancel program
    Novelist:
  • 85 Answers
Hi Try disconnecting printer cable and printer power cable for at least 1 minute.
Should reset to default.
Good Luck!
Tinteiros (Ebay)
Posted on May 29, 2008
How can i clear buffer on hp 3020 all in one laser
Why not let it complete remainder printing after cancelling the job.
You may also pause printing, remove most paper from paper trays so that it run out of paper then then power cycle the printer.
Nov 18, 2013 | HP LaserJet 3055 All-In-One Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
kw7157@yahoo.co.uk
Mar 20, 2009 | HP LaserJet 4100 Printer
HP laserJet 5000 Printer continually printing same page
laserjet 5000 printer A4 size printing right side line not printing .why?
Jan 14, 2009 | HP LaserJet 5000 Printer
HP 4SI print black page
hi,,
try to replace a different toner of your printer..
Oct 29, 2008 | HP LaserJet 4si Printer
Hp laserjet 1000 series problem
Time to clear some space on your hard drive. That's where virtual memory is paged to and from. Delete some files you don't need, and run defrag. Then your operating system will have more room to buffer the pages to the printer.
Sep 11, 2008 | HP LaserJet 1000 Printer
Wont print properly
63 NEEDS SERVICE ليزر جيت 4
Jul 17, 2008 | HP LaserJet 4si Printer
HP 4si keeps jamming
This pdf might be useful, it will show you how to change the rollers. Hope this helps and let us know if you need further assistance. if the pdf does not open you can find it at this link, it will be the very first link which will open the pdf.
May 30, 2008 | HP LaserJet 4si Printer
Hp 4si laser jet prints the page with heavy dark toning on both edges right & left . Lately toning dark over the entire face of the page , makes otherwise good printing hard to read . The edge toning is...
Hi, When I've worked on printers with this problem in the past it usually comes from the high voltage power supply going bad. There is also a low voltage power supply that runs everything except the actual printing so your printer will still operate without any errors but the print quality will go bad. The high voltage power supply is located under the bottom of the printer and it's too hard to replace. I can't advertise for any place on this site, but if you type in the part that you need into a search engine and look for parts on everyone's favorite bidding web site you should find the parts you need. Good luck.
Sep 04, 2007 | HP LaserJet 4si Printer
Open Questions:
HP LaserJet 4si Printer Logo
140 people viewed this question
Ben Johnson
