Question about Sony Playstation 3 (PS3) Console
When connecting ps3 to Hdmi tv via hdmi lead or av connection ,ps3 is powering up ok but error message appears on tv screen saying game mode not supported.
  • Sony Master
  • 1,525 Answers
Hello,,when you connect a hdmi you have to into the menu and select hdmi this should give you a 1080p picture mode
regards
shaun
Posted on Oct 08, 2010
When my son plays his PS3 after a while the screen goes blank and the message: check signal cable appears. His PS3 is connected to tv with an HDMi cable and the cable that fits into the AV with the three...
Try these steps:
1. Before resetting cables, make sure PS3 is turned off using the main power switch on the back.
2. Unplug the power cord of the PS3 and TV from the wall socket.
3. Connect HDMI cable to HDMI Out on back of PS3
4. Connect HDMI cable to HDMI Input port of the TV
5. Plug the PS3 and TV back in to the wall socket
6. Turn the main power switch on the back of the PS3 on.
7. While the PS3 in standby mode(red light on) hold down the on/off button on front of system until the system goes into standby mode again. (So the light cycle would go red light-green light-then back to red. This will ensure you held down long enough to reset video output settings.
8. Turn on the PS3 and once the system finishes powering up, the video output settings will automatically reset.
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Problem connecting my ps3 to my samsung le23r71bx tv using an hdmi lead. I get an error message "mode can not be supported"
    1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
    3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    Jun 28, 2010 | Sony Playstation 3 (PS3) Console
    PS3 HDMI - Sony Bravi KDL-40V2000 Problem
    • Have your ps32_bing.gif in standby mode (red light).
    • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
    • Wait 10-15 seconds. A display will show up, and just answer yes to all!
    try this
    May 08, 2010 | Sony Playstation 3 (PS3) Console
    PS3 HDMI connection issues
    try video reset
    when ps3 is in standby mode(red light)
    press and hold the power button till you hear a second beep.
    standby mode press hold power........"beep"......"beep"..release power button
    Oct 21, 2009 | Sony Playstation 3 (PS3) Console
    Connecting ps3 to hd tv
    ok here's what you do. Hook up your ps3 to your hd via hdmi cable then turn the tv on first. Then turn the power on to your ps3 and switch tv to hdmi. wait a while then a screen should come up and you should see and screen where it says an hdmi device is connected do u want to accept theses settings say yes. sometimes the "handshake" doesn't happen properly. If u already know this or have tried this it could be that your tv needs a firmware update, happened to me.
    Jan 12, 2009 | Sony Playstation 3 (PS3) Console
    JVC LT-32DS75SJ issue with HDMI
    Try this
    1. Turn ON TV
    2. Connect PS3 to TV HDMI input
    3. select TV HDMI input for PS3
    4. turn OFF PS3 if it is ON
    5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
    Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
    Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
    PS3 No picture or sound
    When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
    Jun 25, 2008 | Sony Playstation 3 (PS3) Console
    Shadowing on screen
    You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
    bimmerhp
    Jan 23, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    323 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
