Question about C3RS727LCD 4Channel Alarm with Remote Car Starter and Two Way AM
How do i cancel sleep mode? - C3RS727LCD 4Channel Alarm with Remote Car Starter and Two Way AM
Kenmore 70121 air conditioner
There should be a sleep mode button on the remote. Press this then pres ok/enter.
Note: In this "MODE" the selected temperature will increase by 2 degrees F 30 minutes after the mode is selected. The temperature will then increase by another 2 degrees F after an additional 30 minutes. This new temperature will be maintained for 7 hours before it returns to the originally selected temperature. This ends the "Sleep" MODE and the unit will continue to operate as originally programmed. The "Sleep" MODE program can be canceled at any time during operation by pressing; Sleep MODE, "On/Off", "Fan Only" or the "V//X" buttons, on either the Control or the Remote. "Time Delay Stop" limit reached will also end "sleep" MODE.
Jun 01, 2012 | Kenmore Heating & Cooling
Hello, We have just transferred our AWA DVD 5.1 Home Theatre System for improved sound to our television from our home theatre projector. I was wondering if there is any way of turning off the sleep mode...
Just go into the device sleeper mode and now used the romte pushes the SLEEP button on the remote a few times to make sure the SLEEP mode timer it is to be turn off.This problems should be solved.
May 09, 2011 | Televison & Video
We have a Sony Trinitron Color TV that seem to be in a sleep mode and we can't turn it on. Would you know what the problem is?
Hello
Press the "Sleep" button on your Sony's remote control hanset until the TV displays the time in minutes [ 15,30,45,60 or 90] that you want the the TV to remain "on" before shutting "Off" automatically. Cancel by pressing until "Sleep Off" appears. The logo also will go out from the screen.
You just do this after unpluging the TV from AC wall socker for about 10 minutes or so, and then plug it.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
Whenever I step away from my Macbook Air (running 10.5.8) and it goes to sleep, when I come back it says that it tried to shut down Firefox but could not. Then I have to go through several steps to cancel...
I would check the energy saver settings under system preferences and see if it is set to go to sleep after a period of time. Also check the schedule button under energy settings to see if there is a scheduled sleep setup. Hope this helps
Mar 24, 2010 | Apple MacBook Air
How do i take the television off of sleep mode
Canceling the Sleep Timer:
1.
Press SLEEP on the remote control.
2. Press SLEEP repeatedly until OFF is displayed.
Note: After 5 seconds of inactivity, the message box disappears.
Good luck
Oct 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Printer will not turn on
I had the same problem. I downloaded the firmware update from 11/08. It seems to have solved the problem
Oct 14, 2008 | Office Equipment & Supplies
Program copier not to sleep at work
  1. Press the [Access A] (key symbol) button on the top, right corner of the Control Panel.
  2. Enter the system password using the numeric keypad, then select [Enter] on the Touch Screen. The default password is 1111.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. To cancel the operation, select [Cancel]. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
  3. If the Internal Auditron is not enabled, select the [Go To Tools] button (does not apply to copier-only models). If the Internal Auditron is enabled, select the [Tools Pathway] button.
  4. Select the [More] button.
  5. Select the [Power Saver Administration] button.
  6. Select the [Set Duration Times] button.
  7. To adjust the 'From Standby Mode to Low Power Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Standby to Low Power may be set between 1 - 120 minutes.
  8. To adjust the 'From Low Power Mode to Sleep Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Low Power to Sleep may be set between 0 - 120 minutes.
    NOTE: There should be a minimum of one minute between the 'From Standby Mode to Low Power Mode' and 'From Low Power Mode to Sleep Mode' settings. For example, if the 'From Standby Mode to Low Power Mode' is set to 10 minutes, then the 'Low Power Mode to Standby Mode' should at least be set to 11 minutes.
  9. Select the [Save] button.
  10. Select the [Exit Tools] button.
Sep 27, 2007 | Xerox CopyCentre C128 Black and White...
C3RS727LCD 4Channel Alarm with Remote Car Starter and Two Way AM Logo
258 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
