Question about Carrier Heating & Cooling
Have a 48ss 036080311aa Carrier packaged unit , flame is rolling out and heat is going down on the overheat sensor, getting 7 flashes on the controler board
  • 767 Answers
Hello my name is Heath it will be my pleasure to assit you. It sounds like the heat exchanger is plugged. Pull the burners and use a shop vac an clean the heat exhanger out real good use a brush if you have one long enough to brush the heat exchanger out.
Posted on Oct 08, 2010
Carrier infinity 80 won't heat
does your burner flame up and then go put two or three times if so
all you have to do is take out the burner and clean all the soot out of it and then wipe off the sensor
Oct 09, 2012 | Carrier Infinity Series Variable Speed...
Carrier package unit. 48SS series. Condenser fan continuously runs even when T-stat is off.
The one side of the contacotr in the condenser electrical box is welded closed...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 08, 2010 | Carrier 38CKC036 Air Conditioner
Carrier furnace ,burner not staying on after 4th try shuts down completely.cleaned the flame sensor but noticed the 3rd and 4th burner has a delay in lighting by the time the 4th burner lights and hits the...
Remove them and scrub them with a wire brush.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier spit type air conditioner 5 blinks
Hi, you should have a error chart on one of the panels of the unit that will tell you what the 5 blinks mean. It will be pasted on the unit inside some where. Let me know what you find and we will go from there. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier furnace, pilot does not light, fans run for a couple minutes and then flashes code 31
Nov 28, 2009 | Carrier 38CKC042 Air Conditioner
The heat turns off after 3 seconds of flame.
There is a flame sensor failure.
Here is the ignition sequence for a furnace. This will help you understand what is happening/not happening.
Thermostat2.gif calls for heat.
draft inducer motor (DIM) starts drawing draft through heat exchanger.
Pressure switch detects proper operation of DIM, and sends signal to board to begin ignition.
(it detects negative pressure)
Ignitor starts ignition attempt and gas valve sends gas to burners.
Upon ignition, flame sensor detects flame and sends signal to board stopping ignition sequence and continuing gas flow for heat mode operation until thermostat is satisfied.
During this sequence the blower motor is brought on, and by using a series of temperature limit switches, the system assures that the unit is operating properly.
(If the blower is not operating, or the airflow is inadequate, the heat exchanger will overheat and trip one or more temp limit switches.)
There is also a "rollout" switch that detects improper flame pattern "rolling out" into the controls compartment.
Now, to apply that to your situation.
If the flame sensor does not sense flame, it shuts down the furnace to prevent a dangerouse gas build up.
With most modern glow coil ignition systems you have one of two failures.
1) the flame sensor is bad and needs to be replaced.
2) the control board is not proccesing the signal from the flame sensor and shuts the system down. In that case the board would need to be replaced.
There is a possibility that a temperature limit or roll out switch is breaking the curcuit, but that would be quite unusual to happen consistantly at three seconds.
Unless you have the ability and tools to test the snesor and board, the next step would be to replace the sensor first, and then the board if that does not fix it.
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Furance not staying on
The flame sensor is not sensing flame.
You can try cleaning it, but will probably have to replace it.
When the sensor does not detect flame after ignition, it will shut down the gas flow.
Oct 01, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
151 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
