Question about Hotpoint Ultima WF860 Front Load Washer
My hotpoint wf860 washing mashine says f10..what does this mean?
  • 15,935 Answers
F10 indicates the pressure switch isn't sensing a change in the water level.
Unplug the appliance and take the top off.
The pressure switch should be on the left near the top.
Take the thin tube attached to it off.
Blow as hard as you can down the tube for as long as you can.
Give the pressure switch a couple of good taps with your screwdriver handle.
Refit the tube and try the machine again.
Ensure the wiring and plug to the pressure switch are good.
If your hotpoint washing machine is not working and you feel it needs repairs and you are getting the E10 or F10 error code, this means there is NO cold fill and you should check and verify that the taps are on and that the hoses are not kinked.
The first thing to check is the taps, most machines will have the hot and cold fill supply plumbed via a hot and cold inlet valve placed under a sink or directly behind the machine, it is usually a silver valve with the Blue and some times a red flexible hose connected to it, the blue should be cold and if there is a red that will be the hot supply.
In the on position, the plastic switch located on the side of the in let vale should be pointed in the same direction as the arrow on the valve and in the off position it should be pointed across the valve, if it looks off, especially if your valve is under a sink where pots, pans, boxes and other item can get pushed up against it and could turn it off by accident, simply turn it back on, but do not force it, as forcing it could break it, and that could lead to a flood situation.
If the valves looks OK, but the washing machine is still not working and you still get the E10 or F10 error message, you now need to check for a kinks in the pipes, this will probably mean pulling the washing machine out from its housing to continue the repair.
At this stage you need to take in to consideration the fact that the washing machine will be heavy and connected to both the mains electrics and mains water supply and also that putting the machine back properly can often be harder than taking it out.
If you are unsure, you would be best advised to call a engineer, if you are not willing to pull the washing machine out you could still also check any part of the inlet flexible hose pipes that you can easily see, like in the cupboards and also to the side of the washer, if you see any kinks, you could try to remove the kink and test the machine again.
Error codes are usually machine specific and the diagnosis given here is for the hotpoint unit only, do not relate this diagnosis or error code meanings to any other make of washing machine
Thanks for using FixY%^*
Posted on Mar 04, 2011
F-10 fault code
F10 is indicating pressure switch not sensing correctly.
Check connections from pressure switch to module.
Please rate my solution.
Thanks.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
F10 means that the water level switch is not sensing the correct water level, this can be caused by faulty switch, a blockage in the pressure system, a blocked drain pump or filter.
It is a process of elimination I'm afraid.
Please rate my suggestions to solve your problem.Thanks.
Mar 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ctd 80
The error code F10 is common of heater open circuit or one shot thermostat open circuit.
F8 is indicating static heater relay contact welded closed.
You need to call an engineer.
Oct 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf860 Error Code: F10
hiya
this could be caused by a faulty pressure switch (controls water levels). but due to the machine sharing the same electrical components as indesit it could be a fault on the main pcb.
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Jul 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Alarm Code 10 - Meaning Please?
You can download the manual from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
You will need to contact the service helpline for the explanantion of the F10 display
Dec 30, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
122 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
