I have inserted two new ink cartriodges and up came the message "Printer head ,missing, not instaled or has come loose etc. I have carefully removed the ink cartridges and the printerr head and carefully reinstalled the printer head and then the ink cartridges. Up comes the same message! This I have done at least 12 times! Does it mean I need a new printer head and if so how do I get one? I have an ESP5
  • 13,433 Answers
Hello, and thanks for using FixYa.
I guess you have already seen this video? http://www.kodak.com/global/en/service/tutorials/AiOPrinters/ESP/printHead/01_PrintHead/index.jhtml
Lets do that again, but a small modification to the steps, take out the printer head, notice the small metal pins on its back, make sure they are all clean and not bent or similar. Then continue with video to reinstall the head. Make sure it snaps into place properly.
Now if the problem still persists, unplug the printer for a moment, then plug it back in and power on, if the error still comes up. Perform a firmware update.http://www.kodak.com/global/mul/service/downloads/DownloadFile.jhtml?locsvcsEntryPath=12999&product=EKN035324&operatingSystem=windows_7&lang=en&type=firmware&downloadId=dln00209_file1&variant=false&pq-path=14091
Is your printer covered by warranty? If it is, contact kodak and get it fixed. If you are outside of warranty then it is questionable if this repair would be worth it.
If you still get the same error message, a new printer head might help or it might not, I can not guarantee it in this case. New printerhead costs 90$ http://cgi.ebay.com/NEW-KODAK-PRINTHEAD-ESP-3-5-7-9-3250-5250-5300-5500-/220653674584?pt=Printer_Accessories&hash=item335ffbe058 You may also look for a cheaper head by looking at other ebay items, some sellers have not bothered to post what models their printer head works with, you would have to find out http://shop.ebay.com/i.html?_nkw=kodak+printhead&_sacat=0&_dmpt=BI_Toner&_odkw=kodak+head&_osacat=0&_trksid=p3286.c0.m270.l1313
And again I can not guarantee that it will solve the problem, maybe you can get the seller to agree to return the item if the error does not go away, but most likely they will not take a return once it has been opened.
If the printhead replacement doesn't help, its a more complex problem that we can't fix at home
If you still want to get the printer repaired call kodak at 1-800-421-6699 (US number)
Posted on Oct 08, 2010
Gives message Printhead loose missing or not installed. changed several times same message
If you already replaced Print head then same error occur their might be a problem with the carriage unit. kindly check also if there is a leak inks on a carriage contact then clean it.installed again print head.
May 08, 2015 | Kodak 6150 AllInOne InkJet Printer
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Get msg printer head missing or not installed properly.
First change old head with the new box pack head if the problem presist then it is the problem with carriage unit.
Jan 02, 2013 | Kodak ESP 5 Printer
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Crtg missing instal new ribbon printronix p7005
This error message normally happen due to following reasons..
1. Didn't remove protective tape on cartridge.
2. Didn't properly seat cartridge.
3. Contacts on carriage need to be cleaned.
4.If you inserted and removed Cartridge many times..
Try to do it: You can wipe the copper contact plate on the cartridge over with a slightly damp piece of kitchen towel using distilled water. While doing this you need to turn off your comp and printer. Let the contact plate dry for a minute or two before putting back on.
After inserting the cartridge, run the print head cleaning program 3 to 4 times for best results as this will clean the heads and push the ink through.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 28, 2012 | Printronix P7005 Matrix Printer
How do I resolve an incompatible ink cartridge message?
First, remove the cartridge, if not already done. Second, go into the printer properties and cancel any "pending" print jobs. Third, either unplug the printer or find a reset button (sometimes holding the power button resets the printer to it's factory settings). When doing this, most (if not all {new/newer} printers come with a disc that has a calibration and alignment program that is installed when installing the printer. Four, if unplugging or "resetting" the printer does not work, un-install the printer and then re-install it. After un-installing it, follow the direction for installation as you did when you first installed it. Also, make sure that all compatible cartridges are in the printer. If even one cartridge is missing, when installing, the printer will give you the same, or similar message for the missing cartridge. Please let me know if you need further assistance.
Jan 23, 2012 | Office Equipment & Supplies
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Error message: Printhead missing, not installed correctly or has come loose
In regards to the error message with the printhead missing or come loose......I had that issue just shortly after I installed my printer. I was going crazy trying to fix it taking it out and reinstalling which was a pain, removing the cartridges and then the printhead to no avail. Finally I got smart and disconnected the power cord from the printer itself, not directly from the outlet. Once I did that and turned the printer back on the error was gone. It might have been a fluke, but it worked for me, so you might want to try it.
Jul 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Replace a new Black #70 ink cart, but I get the message, black ink is missing.
Clean the ink carriage that should take care, use alcohol to clean the carriage head then insert the ink cartridge.
Jul 01, 2008 | Lexmark Office Equipment & Supplies
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
116 people viewed this question
jasbo
jasbo
