Question about LG WM3431 Front Load Washer / Dryer
I require a new pump for this unit washer & Dryer WM3431HW. The pump specs are Part# 3660FR1261.2 PP.HK.L.6 120V AC- 60Hz 80W.
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Hi, I have LG washer and dryer combo WM3431HW. How
When I check your model number, the lifter comes up as part # MFE38265101
Changing one,...... oh, you really got to want to. On a difficulty scale of 1 - 10 for repairs on this washer / dryer combo, I would rate it about a 10. Basically, you have to remove the motor, remove the entire outer drum, seperate the halves of the outer drum allowing removal of the inner drum, and eventually removal of the lifter from the back side of the inner drum. If you can do the job in under two hours I think you would set a world record.
Posted on Mar 13, 2011
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front door is locked and I cant get my clothes out.
http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp
Check this link, and click on the right side, for the pdf file, to read the manual. Hope this helps.
Mar 29, 2010 | LG WM3431 Front Load Washer / Dryer
Where can i find a free service manual for LG WM3431HW?
Unfortunately you won't find one.
LG only supply their servicing manuals to their repair centres and strictly enforce their copyright, so the manuals are not available to the public and when they do occasionally appear the material has been stolen.
Usually I'd recommend a generic repair manual such as the one by Haynes, but LG's direct drive system and a number of other unique technical features mean that the Haynes book isn't as useful as it could be. The WM3431HW is a large capacity and technically advanced washer dryer so it's certainly not as straightforward to service as a traditional front loading washer or dryer. Many LG spare parts can also be difficult to source outside of their own approved servicing organisation.
I respectfully suggest that you either get LG to fix your machine or post a question on this site describing the problem to see if we can assist you.
Mar 26, 2010 | LG WM3431 Front Load Washer / Dryer
Need to convert 120V AC/DC current to 120V AC 60Hz 15W
there is no such thing as "ac/dc" current-its either one or the other--if its a 120 Volts then chances are it is AC already-at 60hz---the 15 Watts or any Watts is the amount of draw from the unit-not the power supplied to it- Watts= Volts(supplied)/Amps(being used) if you only want to supply 15 watts then reduce the amps (with a fuse) to .125amps
Mar 26, 2010 | Computers & Internet
Lost power cord
Specifications:
  • Manufacturer: HP
  • Input: 100-240V, 50/60Hz
  • Output: 32V, 16V
  • You can get more information here:
    http://www.unitedsale.com/product_info.php?products_id=18583
    Please vote me if you like my post.
    May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
    What ac adaptor does the canon 5000F require (New Zealand)?
    Specification:
    Input :100-240VAC (50-60Hz)
    Output : 12Vdc 1.25~1.5A
    those are the specs on it.... any adaptor with 12 volts dc. output of at least 1.25 amps will work you can find them at most electronic supply stores... walmart probably even sells them
    Mar 16, 2009 | Canon CanoScan 5000F Flatbed Scanner
    NEED SPECS FOR POWER SUPPLY OF DDV-1100X
    have the adaptor you require....model AD2910-0207 INPUT :- 100-240VAC, 50/60HZ 0.3A OUTPUT:- 5V -2A....AC ADAPTOR hope this helps....hope you can help me i have no software (drivers) for this camera. can you assist. pete
    Jan 17, 2009 | Cameras
    LG WASHER/DRYER
    Try checking the back, there is a plastic tub that is connected to the drying system and it can get clogged with lint etc. It will also cause the unit to give you longer drying times. It is a poor design. You can also pop off the lid to get a better look but make sure you unplug the unit.
    Sgt 48
    Jun 09, 2008 | LG WM-2277HW Front Load Washer
    Crown XLS 802 D Amplifier Transformer!
    You will need AC to AC converter that will accomodate US to UK mains. Look for power requirements of your amp on name plate and match with available converters online. Make sure power line frequencies match in/out requiremnts
    Apr 17, 2008 | Crown XLS 802 D Amplifier
    Open Questions:
    How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
    Jul 16, 2014 | LG WM3431 Front Load Washer / Dryer
    Additional details: Questions with more than 25 words are more likely to be answered well. 0 chars Your Question Preview No product selected LG WM3431 Front Load Washer / Dryer How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
    See all LG WM3431 Front Load Washer / Dryer Questions
    LG WM3431 Front Load Washer / Dryer Logo
    116 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
