Question about Cycling
I am search for magic one speedometer MG-CW9 setting manual. especially the code list related to tire diameter, can you help?
2 Suggested Answers
  • 457 Answers
SOURCE: sir,is the unequal diameter of tire is related to abs faults..thanks
very possible; the abs system looks to see that all the wheels are turning at the same speed
Posted on Mar 25, 2013
I dont know which Magic remote to get for it
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Jul 12, 2016 | Televison & Video
I do not know serial number or mg The remote is not new. I tried dvd and set up button but do not know code
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 06, 2015 | One For All URC-3021 Remote Control
How to program my lg magic remote with my dish tv box
I'm wondering if the original question "How to program my lg magic remote with my dish tv box" was ever answered, and if the problem was eventually identified and resolved. (none of the answers above seem to be solutions).
I have the same problem - unable to control my Dish receiver (VIP722K) with my new LG Magic Remote - and LG support wasn't able to help. Is this a known compatibility issue?
Jan 25, 2013 | Televison & Video
My car tires were the standard size P185 65 R14. They were recently changed to P185 60 R15. Will this cause any problems on this car?
Original tire
Sidewall: 4.73 in
Radius: 11.73 in
Diameter: 23.47 in
Circumf: 73.73 in
Revs/mile: 859.37
New Tire
Sidewall: 4.37 in
Radius: 11.87 in
Diameter: 23.74 in
Circumf: 74.58 in
Revs/mile: 849.54
Speedometer reading with new tire is 1.16% too slow.
When your speedometer is reading 60mph you are actually traveling 60.69mph.
Sep 18, 2011 | 2001 Plymouth Neon
What is the difference between tire size 255/70 and 265/70
Hello Projocs03,
Tires are typically measured tire width (sidewall)/tire ride height/wheel size. The differences of the two tire sizes you published are .4 of an inch difference in width/sidewall. And about .55 in over all diameter which would impact you revs per rotation. Depending on your wheel size.
Attached is a comparison of the two given the variable of 17" rim.
Stock Tire >Search Tires Tire 1 - 255/70R17 >Search Tires Tire 2 - 265/70R17 >Search Tires Section Width: - - Section Width: 10.03 in 255 mm Section Width: 10.43 in 265 mm Rim Diameter: - - Rim Diameter: 17 in 431.8 mm Rim Diameter: 17 in 431.8 mm Rim Width Range:
Rim Width Range: 6.5 - 8.5 in Rim Width Range: 7 - 9 in Overall Diameter: - - Overall Diameter: 31.05 in 788.67 mm Overall Diameter: 31.60 in 802.64 mm Sidewall Height: - - Sidewall Height: 7.02 in 178.30 mm Sidewall Height: 7.30 in 185.42 mm Radius: - - Radius: 15.52 in 394.20 mm Radius: 15.80 in 401.32 mm Circumference: - - Circumference: 97.54 in 2477.5 mm Circumference: 99.27 in 2521.4 mm Revs per Mile: - Revs per Mile: 669.8 Revs per Mile: 658.2* Source http://www.1010tires.com/TireSizeCalculator.asp?action=submit
I added the above link so you can research further or change any variables you need to know. However, the most important thing to understand is the impact of your speedometer. Different sizes will have different impacts. For example going to a bigger tire will show a slower speed on your spedo that your traveling.
Good luck
May 25, 2011 | 1997 Ford Expedition
Can 215/65/16 tires on a 1999 Caravan be swapped for 205/60/16 tires?
Yes, you'll be o.k. They don't recommend anything over 3% difference, and your at about 1.8%. Speedo will read 61 mph when actually doing 60 mph. Have a look.
Stock Tire - 215/60R16 >Search Tires Tire 1 - 205/60R16 >Search Tires Section Width: 8.46 in 215 mm Section Width: 8.07 in 205 mm Rim Diameter: 16 in 406.4 mm Rim Diameter: 16 in 406.4 mm Rim Width Range: 5.5 - 8.5 in Rim Width Range: 5.5 - 7.5 in Overall Diameter: 26.15 in 664.21 mm Overall Diameter: 25.68 in 652.27 mm Sidewall Height: 5.07 in 128.77 mm Sidewall Height: 4.84 in 122.93 mm Radius: 13.07 in 331.97 mm Radius: 12.84 in 326.13 mm Circumference: 82.15 in 2086.6 mm Circumference: 80.67 in 2049.0 mm Revs per Mile: 795.4 Revs per Mile: 809.9 Actual Speed: 60 mph 100 km/h Speedometer1: 61.0 mph 101. km/h Speedometer Difference: - Speedometer Difference: 1.822% too fast Diameter Difference: - Diameter Difference: 1.8%
Nov 07, 2010 | 1999 Dodge Caravan
Why is the speedometer reading faster than the bike is really traveling?
Because the tire is a smaller diameter then it needs to be to give you an accurate reading. If a tire diameter is too big , you will get a slower reading on your speedometer. If a tire diameter is too little you will get a higher reading on your speedometer. A tire that is manufactured can say it is a certain size , but it can bigger or smaller than that size with in a certain percentage and still be the size they say. Say you are running a 100/100x19 and your speedometer reads too high a speed. Then, when you replace the tire try a 100/110x19 size (taller) and you may be able to correct the inaccuracy.
Oct 21, 2010 | 2005 Honda VTX 1300 R
Is there anything I could do to bring my RPM's down when Im driving in hwy. I have a 96 t100 4x4 stick, stock. At 70mph rpm is at 3300. I changed to manual hubs and that helps a little.
The only way to accomplish that is to change the axle gear ratio. Trucks are generally geared for hauling, towing, plowing, etc, so you have more torque and power at lower speeds. If you change the axle ratio,your low end performance will probably suffer (sluggish acceleration at low speed). Basically, your T100 is not designed for 70mph highway driving.
Mar 23, 2010 | 1998 Toyota T100
What other size tire can i use on my 2008 xd scion
Contact your Goodyear Tire dealer or other fine retailer ... he or she can tell you all your options and give you prices at the same time.
Feb 22, 2010 | 2008 Scion Xd
Can you change the tyre size set up on a bmw x5 without any issues
Yes and no. Yes you can change the tire size and go up. Your car is equipped with 225/50-17 if I am not mistaken. What you need to be concerned with it not increasing or decreasing the overall diameter of the wheel/tire combination. The diameter of you wheel/tire is 25.9". If you go to a larger or smaller diameter tire you speedometer and odometer will be off. To check the sizes and how they effect the diameter go to this site. Put your OEM size in and then check different sizes and how they effect diameter. http://www.miata.net/garage/tirecalc.html You can on some cars, for a fee, have the ECU reprogrammed for a larger tire by the dealer. Contact your BMW dealer to find out.
Jan 07, 2010 | 2007 BMW 530xi Sports Wagon
Cycling Logo
90 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
