Question about Car Audio & Video
Is 115v can be used in 110v power. - Car Audio & Video
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Should be able to.
Posted on Oct 08, 2010
Can I use makita 5007nb circular saw on 220vAC.?
i assume it will overheat and burn up at 220 volts. its not made for that. make up an outlet with one hot and a neutral off the 220 line
Feb 17, 2018 | Makita Saws
What is the voltage required to run rival hand mixer?
This plugs into a standard 120v household outlet, it's only 150 watts, running 10 of these is like one hair dryer. Most products say 110v, 115v in the USA.
The actual voltage is around 120v at the breaker panel and around 118v at the outlet.
But all products marked 110v, 115, 117, all work on a standard outlet.
Apr 14, 2013 | Rival 150 Watts MX555-W Hand Mixer
Can you run 110v from a 115v geni*tools)
I'm a little confused about what 'geni' is.
The outlets in your home are rated at 120v AC and any equipment that you plug into them that state 110v or 115v will work fine.
If you are referring to some type of adapter that you plug into a wall and then into some electronic unit, be careful. It isn't just the voltage that you should be concerned with but the amperage!
Adapters generally take the AC current from a wall outlet and then convert it into DC voltage. This voltage is more or less specific to each device that requires DC input. As a basic rule, you must match the exact VDC and mA from your device with the same values on an adapter.
Jan 15, 2013 | Computers & Internet
My dewalt drill is 3pin 110v I need to step up to 240v
You cant convert to 240 the plug you have is a 30 amp 115 volt
Nov 07, 2012 | Drills
Power Plug Adapter - Converter - 110V - max. 1550W US/Japanese to Australia
You need a stepdown transformer from 240 volts to 110 volts AC.
Make sure you get one that has the required wattage you require.
Jaycar has a 1000W 240 - 115V Cat. No. MF-1086 for $360.00
**** Smith has a 1000W 240 - 115V Cat. No M1154 for $246.00
If you require a higher wattage, try an electrical wholesaler.
Jan 14, 2012 | Video Game Consoles & Games
I have a 240v drill and need it converted to 110v as I can't use it at work. It is the Hitachi DC 30PC2.
Unfortunately thi sis not really possible internally, you need to purchase step up transformer 110V/115v 220V230V/240V with at least 2A rating, 50Hz/60Hz frequency and at least Watts as are on your drill, that is, I am afraid only solution to your problem. Check prices of the transformers as maybe purchse of new drill will be less expencive.
As you did not stated where you are, I cannot advice more closely where you can find these, for beginning I would suggest chasing one (step-up!) on auction sites and electrical wholesalers, tool dealers.
Aug 18, 2010 | Drills
I HAVE A 115V USA HAIR CLIPPER.LIVE IN UK, SO
Look on the side of the clipper handle. You ahould see what appears to be a screw. With your clipper plugged in and turned on, turn that screw with a screw driver in either direction, the noise you are talking about should quiet down quite a bit,
Aug 21, 2009 | Oster Health & Beauty
Need to chat with an agent!
1. make sure not only those are properly seated on the led portion of the the case and on the motherboard..
2. also check your power supply motherboard connector is properly seated on the mother board
3. and make sure your power supply switch is on the right postion (110v/115v North america or 220v/230v Europe)
4. make sure the wall outlet plug is working properly. and properly connected to the back of the powersupply
Dec 04, 2008 | E-Machines eMachines Desktop PC
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
