Question about Electrolux Refrigerators
I have a big buildup of ice in the right hand side of the fridge and the freezer is too cold i defrost it regulary because of the problem
  • 4,793 Answers
Most common problem is seals not fitting all round, allowing an air leak into the fridge,also if you have a drain hole inside at the back,check its not blocked......
Posted on Oct 08, 2010
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
My regrigerator (GE Profile) is not cold on the fridge side, but ok on the freezer side. I found ice buildup in the freezer so I defrosted and dryed it completely, cleaned it- including coils...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | GE Refrigerators
The freezer side is very cold but in the refrigerator not much cold.
Check evaporator fan inside the freezer
Check condensor fan underneath in back
Check for ice buildup in the evaporator coils (Defrost Problem.)
Also ice and/or frost on the back wall of freezer (defrost problem)
Check air vent for ice block from freezer to refrigerator inside the fridge.
Should have low air volume to fridge from freezer.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Heating & Cooling
It's too cold in the top freezer, yet not cold at all elsewhere
if your freezer is cold but your fridg isn't then you have a defrosting problem. behind the back wall of your freezer you will probably find a very large mass of ice. unplug your ref and using hot water melt the ice. you will need several large towels for this since it will make a mess. once the ice is cleared if you have an ohm meter you can check the defrost element you are looking for continuity( closed circiut) if that tests ok find the defrost termintor(also called a bi-metal defrost) it is about the size of a quarter and is usually located in the top left side of the freezer. It will be clipped to one of the tubes. if it looks like it has popped then it is bad. If the bi-metal looks ok you will need to hook the element back up and go to the control panel in the fridge. looking up at it you will see a small hole and a gear inside that you can turn with a slotted screwdriver. turn it until you hear it click and the fans stop running. if the defrost heater comes on then change the defrost timer(the part you just turned)
Apr 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Fridge side of side by side Frigidaire not working
your damper door is frozen or iced up and not opening up to let cold air in from freezer compartment,defrost it and make sure its dry,also check your door seal to make sure its sealing good and not letting in warm air that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
FREEZER SIDE TOO MUCH ICE FRIDGE SIDE NOT TOO COLD
If it has ice buildup on the back wall inside the freezer, it appears to have a defrost problem. Unplug it, put your food in another unit (or ice chests), open the freezer door and let it thaw out overnight for at least 12 hours or more, or until all the ice has melted from *behind* the back wall. Then close the doors and run it for 4 hours and check to see if the fresh food side is cold. If it is, call a repairman to fix the defrost problem. That could be a burned out heater, terminator, or defrost timer depending on your exact model.
Jan 03, 2010 | Whirlpool Refrigerators
Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
Sep 21, 2009 | Kenmore Refrigerators
I have a kemore elite fridge wont get cold
It can be the defrost timer,defrost element or defrost thermostat or a blocked vent into the fridge
Aug 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Fridge not cold - freezer fine
ice buildup will most likely block the air flow.
if so the air will not be able to enter fridge section. Check air vent in fridge side if you can hear the fan and get no air flow then its blocked - common defrost thermostat failure.
to temporarily clear the problem just use a hair dryer on the ice build up area
Aug 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
