When i click on print tab the message pop up with sound " the document failed to print" what to do now, i have hp laserjet 1100
    Scholar:
  • 64 Answers
Three things ...
check that your Printer has no error: no paperjam, paper in the paperholder ink is full, etc....
Then the next step is to verify you have the correct printer driver installed on your pc. I assume this is correct as you were able to print prior to the issues occuring I assume.
lastly ... poweroff the print, poweroff your pc, wait 10 seconds... turn on your printer. Turn on your pc.
also check when your pc has turned on that the print queue is not in offline mode.,
good luck ... hope this helps
Posted on Oct 08, 2010
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
My HP Laserjet 3050 frequently pauses when I try to prints PDF documents, but everything else seems allright. This is causing a problem and when the printer is trying to load the document it is like it...
When you select your printer from Acrobat you need to click on the advanced tab on the lower left of the print driver window and set it to print as graphic. This will speed up printing dramatically.
Sep 05, 2011 | HP LaserJet 3050 All-In-One Printer
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
cberamesh@gmail.com
Aug 24, 2011 | HP LaserJet P2015 Printer
Hp laser jet 1100 printer cannot print a document?
Refer the below link if hp laser jet 1100 printer cannot print a document
http://tinyurl.com/mrajesh171
Jan 03, 2011 | HP LaserJet 1100 Printer
HP LaserJet 2015 printer series - PCL XL ERROR is reported during printing
First Solution :
1. Disconnect the Power Cor from back of Printer ( while printer is has power )
2. Wait for 10 seconds
3. While holding Power Button, Connect the Power cord and release the power button
2nd Solution :
This issue can be fixed by enabling the following option in Printer Preferences . To access Printer Preferences , follow these steps:
  3. Right-click HP Color LaserJet 2015 PCL, and select Printing Preferences .
Jun 18, 2010 | HP LaserJet P2015 Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
How do i clean the print heads on my HP Laserjet 2500 on my Mac 10.5?
There should be a print utility tab when you bring up your printer to print a document. Click on it and then there should be a nozzle check option.
Dec 31, 2009 | HP LaserJet 2500N Printer
My hp laserjet 1100 doesnt respond when i try to print
Not sure if this will help but if you right click on the printer and go to properties ( when your in printers and faxes ) and go to the ports tab I think it is and un tick the check box that says bi directional support and try it again.
Also what error are you getting thats printed off ?
what lights are on the printer and where are you getting the driver from, if the disc then try the latest driver from the hp website
Apr 22, 2009 | HP LaserJet 1100 Printer
Printer not printing
when you click the print icon, when the next window pops up are you selecting your printer in the drop down box, and make sure the printer is set as default.
Sep 28, 2007 | HP LaserJet 1100 Printer
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
