Question about Motorola Mobility V360 Cellular Phone
The speaker is so low - Motorola Mobility V360 Cellular Phone
    Problem Solver:
  • 11 Answers
Hardware problem... contact moto care
Posted on Oct 08, 2010
Recommendations for replacement 6 inch speakers with the Jensen AWM 968? They are for my rv, and are the only speakers in it. Thanks in advance for any help!
In-car entertainment systems, especially the types chosen for camper vans, etc., are often capable of quite high power outputs and usually need speakers capable of being driven at those high power outputs without damage.
The trouble is, such speakers usually don't sound so good at the very low volume settings needed for evening and late night use in a campsite environment to avoid annoyance to neighbours.
It is a big problem choosing speakers that sound good at low volume and yet can withstand the higher volume needed to overcome the wind and road noise of driving. There have been many technological advances in speaker design and a hi-fi specialist will undoubtedly be able to make suitable recommendations that are resistant to damp conditions, long-lasting and with cones free enough for good reproduction at ultra low volumes but robust enough to withstand high power outputs and such drive units are likely to be fairly expensive.
For myself I would choose to use a dual speaker system with a multi-speaker system comprising several low-powered speakers strategically placed for low volume use and a fairly standard high-powered system for normal use and a selector switch.
Aug 01, 2016 | Jensen Car Audio & Video
Nokia asha 200 very low earpice sound speaker replaced but same problem
I have a problem with a nokia asha 200 phone that is very low sound for calling to any voice call ,then i am changed speaker but same problem present low sound
Nov 14, 2012 | Nokia Cell Phones
I have very low speaker volume on one speaker, i have checked the system with another speaker....it works
hi,
may be its speaker have some problem. its tweeter is working that's why u get a very low volume through that speaker. change the speaker in side that box and then try.
ok
Dec 23, 2010 | JBL SCS125A System
The volume of my speaker is so low, i cant barely hear it, i cant see anything wrong with it, i checked the AC in, i checked the jack for any short circuit still iget a very low volume out of the speaker...
look on the lower right corner of your screen. there should be a volume icon down there. it looks like a speaker. click that and see if it is set up or down low. if it is low turn it up then it should work. this controls the amount of sound coming out of the sound card on your computer.
Jun 27, 2010 | Creative Labs : Creative Inspire 2900 2.1...
Stock audio wiring diagram
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 11, 2010 | 2003 Kia Sorento
Low volume on creature speakers
Your speaker volume must have reset. You have to touch the dots on the right speaker to turn up the volume to desired volume. I just remembered that on my system. Hope this helps.
Jun 14, 2009 | JBL CREATURE II Computer Speakers
Replaced rear factory speakers now have low volume
Factory speakers usually have low resistance ( 2 ohm) When replacing speakers with aftermarket, most aftermarket speakers will be 4 ohm. If you want the same sound you may have to buy some resistors to put on the speakers (across the + and -). By putting a 4 ohm resistor across the connectors will now make the speaker 2 ohms which in effect will raise the volume. Depending in what vehicle you replaced the speakers the resistance will vary.
May 18, 2009 | Sony CDX-GT500 CD Player
Low volume in speaker
use amp or sound blaster
Mar 29, 2009 | HP P5302M Computer Speakers
Very very low sound/output
Helle there!
First!
1) check your setting for sound to (2 way speakers)
2) Setting for Volume in control panel.
3) connector may be you need a little expantion from radio shack gold ext.
4) be sure you got sound from headphones !! **
Go it!
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
Sony Xplod Car Audio Amplifier
When the protect mode is activated,always be the audio amplifiers IC's damaged you gotta change them.
Jun 05, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Motorola Mobility V360 Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
