Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 makes a scraping sort of noise when it starts to spin. It sounds like the drum is rubbing on something. The noise is better when the drum is up to full speed. Sounds okay when it is agitating. Could this be fixed by installing a new bearing set? Is this a job that can be done by a experienced homeowner fix-it type of person? Thanks - HH
  • 2,272 Answers
A loud whining which gets louder as time goes by is usually an indication of bearing failure...When water passes through the seal on the pulley shaft it gets into the bearings and rusts them..They are no longer smooth..Hence the noise! Slop in the inner bowl increases as the bearings collapse... more in detail:-- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Quite a large job . here is the link where you can see the pictures of this parts as well as buy them if you want:-- http://www.repairclinic.com/Bosch-Washing-Machine-Bearing-Parts
Its more advisable to be done by a experienced tech as it is bit tricky to handle and fix this parts properly.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 08, 2010
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Bosch WFL 2060 makes loud noises when spinning. The drum seems to be very loose and it crashes to the sides of the hull when it spins. i can't find any means to fix it in its position? What can i do?
Welcome to FixYa.
Based on what you`re describing you need a major ocerhaul...or at the very least a rear bearing and inner basket assembly.
This is a major job any way you slice it, however if you want to attempt or are capable of performing the repair I can send you a complete service manual via email.
That means you`ll need to reply to me here and post your email address and I`ll send it in a "pdf" attachment.
I would recommend an authorized B/S/H/ service provider though as it is quite involved, but that`s not my place to say if you feel you can do it.
The part`s are...
# 215113 - Inner Drum/Basket
# 236013 - Outer - rear tank/tub assy.
you could try to replace individual bearings and the seals, but believe me it won`t save you much because either way the inner drum is going to be shot, specifically the spindle, and by the time you try to repair all that you may a well have done the outer tub & basket routs.
Let me know how you make out. Like I said I can send you the info on "how to" but you`ll need to do the work or hire a pro.
Good luck.
macmarkus :)
Jul 29, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Please rate my solution.
Thanks.
Nov 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Lights come on,door locks ,nothing happens on my bosch 2060 uc washer, sweetie says "it was making a funny noise the last time it was working" while it was spinning . thanks!
the engine maybe has no connection or motor is bad thats why wont start up,check if it belt is good ,if need more info let me knw,if my info was of any help to you please comment me ,thank you.
Sep 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Drum makes loud whinning noise when spinning at high rpms.
Remove drive belt.and turn drum by hand, if it feels rough or sounds noisy, then the main drum bearings have failed., also check that the main drum pulley is not loose. If you think it is the bearings, then it is quite an expensive repair.
Plz rate this solution.Thanks.
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
My bosch WFL 2060 Front Loader Washing machine stops mid-way ..
hiya
i'll need a little more info if you can, like what exactly does the machine do or not do?
does it make any strange noises?
does it trip out the electics?
the more you can answer for me the better the diagnoses
thanks kj
Nov 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
97 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
