Question about Samsung SMH7174BC Microwave Oven
Microwave turns off after 1-2 seconds
Problem was intermittant for a long while. Now microwave is unusable. It will work fine for 1-2 seconds, then turn itself off. The display reads 0. Microwave is only a few years old.
  • William Miller
    William Miller May 11, 2010
    It may be a bad connection on the control panel, which we repair for customers nationwide with our guaranteed $39.95 service.
    Or it may be a bad magnetron.
    But please reply back with your brand and model number so we can help you.
It turned out to be the three door attachments that weren't lined up. It has been fixed. We almost bought a new one because Samsung referred us to a service that would have charged way too much to be worth it even thought the machine is only 3 or so years old. Luckily, we looked further. A local independent appliance fixer came to the house and took care of it within a few hours of my call! Yea!
Posted on May 30, 2008
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Tripping GFI
proceed using the common sense. You must open the microwaves for to see what happen, the coffee produce bad contacts, and reaction from component like short, etc. However the following. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 17, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Sensor goes off inside microwave after 10 seconds
Oct 03, 2012 | GE Microwave Ovens
Alarm list says motor rotation and cuts off
Sep 27, 2012 | Microwave Ovens
Error message E8 is shown in the clock display
Error Code: E8 Cause: Control Board Example: Remains in display; oven unusable Corrective Action: Replace control board
Apr 12, 2010 | Bosch HMT8625GB Microwave Oven
Maytag: microwave and wall oven unit together - The oven works fine and the microwave constantly blows a fuse inside the microwave unit - is this a sign of a more serious problem? If so, can I buy a new...
Hi.. It sounds as if you have a Chassis diode that is failing in your Microwave. Intermittent fuse blowing can also be cause by a misadjusted door interlock micro switch. Also you can have the large capacitor inside your microwave chasiss that is occasionally shorting out from use. Based what you described here there is no need to replace the entire unit. Have it repaired as the cost of repair vs replacement are somewhat reasonable.
Jan 04, 2010 | Maytag MMV1153A Microwave Oven
Sunbeam microwave doesnt work
i just brought my sunbeam microwave like two days ago. and it will not heat up
Jan 22, 2008 | Sunbeam SMW777 Microwave Oven
Newish oven powers itself off intermittently
I would look into the thermal shoutdown thermistor inside the micro. It's also posible it may be a bad switch, when power starts, the switch start reacting, not common but I see this posible.
I hope this helps.
Bob
Jan 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
254 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
